Time for a change...Royal purple anyone?
Same here. I could either use 2-4 or 1-3-5, but could not go odd to even or even to odd.
I changed the diff and transfer case oil in my Jeep to RP and mileage appeared to improve and transfer case noise decreased. My 928 tranny has Redline in it now, but I will try RP when it's time to change again.
I haven't noticed any issues with the new M1 although I haven't had it in the car very long either. Can you better describe your observations and did you change viscosities?
Well, my wrench looked at the clutch a little over a year ago and he said there was plenty of meat on it. And I'm not rough on my clutch. Part of the servicing he did on it (along with the RP swap) was replacing the hydraulics - including clutch master cylinder. And it wasn't this bad prior to servicing. Which is why I'm thinking something's out of whack.
I run Royal Purple in everything I own (except my Peterbilts).
there offices are two minutes from my house.....nice to be able to support the local folks.
--Russ
--Russ
Administrator - "Tyson"
No offense to your wrench, if there is a shifting problem on an early 928 that could be a clutch issue and they look at the friction discs......they do not have much experience with these drivetrains.
Sit back, grab a beer and read through these threads:
Pat 1
https://rennlist.com/forums/showthread.php?t=268926
Part 2
https://rennlist.com/forums/showthread.php?t=273590
Part 3 - the fix was finally found
https://rennlist.com/forums/showthre...ghlight=clutch
Long story short since I'm such a nice guy. The release bearing guide tooth broke and was moving on it's own. We are talking about movement that is only a few millimeters. This was enough to push the intermediate disc out of alignment causing a very random shifting issue. The only way this was discovered was 100% dissasembly of the clutch.
Wow, seventeen pages of messages. Can you give be a brief synopsis? I'm heading over to the garage at noon (PST) for other reasons, and I'll ask him about it. He has been a Porsche mechanic since 1978, factory trained on the 928 in 1979. I have a lot of confidence in him based on his accurate diagnosis' in the past. I just want to know what the heck I'm talking about. A P.O.'s wrench botched a clutch job - and Peter caught it before serious damage was done - so I'm thinking that this is either consequences of that botch, or an adjustment of some kind needed because of the hydraulics work.
Double disc possible known issues:
1. air in the system - not as easy of a fix as it should be.
2. intermediate disc is bad. Firction surface will be perfect, the "springs" that hold it's alignment wear out. This is a royal bitch to diagnose
3. In the case of my car, the release bearing was broken. Not in the normal way - pictures in the last two posts I linked to
4. Guide shaft is dirty / warn causing the friction discs to hand up
5. Pilot bearing is sticking
6. Friction discs are worn
7. Master and / or slave are no longer working as intended
8. Ball cup for the guide fork is worn or missing
9. Ball the cup rides on has backed out of his home
10. Clutch fork is bent - very rare, not even sure how it happens
11. I'm forgetting something.....
I put it in the gearbox of my GT to see if it affected the typical cold notchiness. No difference noted hot or cold.......
swepco can help the early transmissions with the problems being discussed here. It was a big improvement for me when i ran the early gear box with my 84.
with the S4, ive been pretty happy with the redline products. 75-90 NS mix with non NS
RP sounds good. probably right up there with redline and amsoil. (although ive been running only amzoil since ive started racing the holbert car 6 years ago , and 91 race days. kind of tough to change something after this kind of a run !
Mk
Mk
He was last in the clutch when I reported that the clutch action wasn't smooth. He found that the previous clutch job was botched; there was a plate on backwards, bolts weren't torqued and the shaft wasn't greased. He fixed everything back up and inspected everything, and he said that he didn't see any serious damage but that my next clutch job was going to be expensive because the shaft would need to be replaced.
Still, this wasn't such a problem prior to the RP swap and hydraulics work.
Does the new Mobil 1 formulation have adequate zinc levels to protect the flat surfaces? I had heard that this is why many older engines are having problems with the newer synthetic oils. If Mobil 1 is no longer good protection, I'm guessing that Red Line, Royal Purple and Amsoil do have adequate zinc additives?
I guess I could go back and search all 5,000 pages of previous oil posts, but I figured it would just be easier to ask.
Update on this.
I switched out to Royal Purple when I had my '79 serviced in December. Somethings are better, some are worse. Specifically, once it's up to operating temperature, it's a very nice experience. However, it's a lot worse when it's cold. Some gears grind terribly, and it's hard to get it into those gears. What's odd (to me) is that the "bad" gears are all on the "back" throw of the shifter; 1st, 3rd, and once even in 5th. Some mornings I just don't want to even try and get to work using only 2nd and 4th. I'm wondering if this isn't really some sort of adjustment issue? But OTOH, why would it not be an issue once it's warmed up? FWIW, it becomes somewhat useable after about 5 miles, much better after 15, disappears by 30.
