My baby is broken.....*torque tube is broken*
#46
Nasty. Remind me to NEVER let you drive my car. LOL. Can't believe that happened the way it did. That looks like a 6k clutch dump with race slicks on the back, not a auto box turning a corner with not even full throttle. Weird.
#47
Damn, those TT pics don't give me that warm and fuzzy feeling if a stock s4 automatic did that at 3/4 throttle.
I wonder what the hell mine is eventually going to look like!
Jim
Jim
#48
Chronic Tool Dropper
This kind of damage is cumulative. Sean just happened to be the person at the wheel when the final failure happened. The failure point looks like a bundle of spaghetti, doesn't it? Anyway, the same torsional displacement that shortens the driveshaft enough to cause TBF also twists it enough to eventually cause this failure. Generally happens at a weak point at one end or the other, where the twist is applied or received.
#49
#50
I'm back home.................................and I almost cried when I saw my car
There are about a zillion pieces on the garage floor. I start my new job on Monday and I realy wanted to pull into the parking lot in my pretty car.
Stupid torque tubes!
#51
Here are some better pictures of the TT
Notice the other end of the TT.
A HUGE thanks to Jim for installing the 230v and 110v outlets this morning. I now have A/C in the garage. Rog came by to lend a hand but Jim did all the work. Was a good morning.
#52
Got the TT today.
Depending on the concensus on the rear flex plate, we should be starting to put her back together this evening.
#54
Just tried to call. Matter of fact, I couldn't get to all the calls from you guys at lunch today, and now I can't reach any of you......
I'm going to stick it back in there. Let's get this party started.
#57
Mike and I got all but the minor torquing and odds and ends in last night. John stopped by to have some pizza also. I'll just need a Hammer to bleed the PSD and she should be done tonight or Thrusday.
#59
Basic Sponsor
I wonder where you could get a Hammer??????
#60
Here's what's left. You can use this as a check list.
Re-connect e-brake cable inside car before your hands get dirty. Install carpeted cover also.
Front flex plate cover
Install large clamps on TT to hold trans lines/vacume line ect.
Install heat sheilds
Install/reconnect axle's
Fill trans with fluid.
Install exhaust-start car before this LOL.
Start car.
Get off Jack stands after checking everything out for leaks/noises ect.
Cool.
Start car.
Cool.
