HELP - Really Bad (Tranny went?)
nighty nite!
Originally Posted by jon928se
Drive shft connected to the CV joint to the diff - probably the bolts fell out of the CV joint - Hopefully as thats the easy fix.
Other alternative is Central SHaft (inside TT) failed.
Ahh, I've always referred to those as half shafts.
As far as the problem, I once stripped the spline gear on the rear of my TT and initially got a shrieking noise and then it acted like it was in neutral no matter what I did. It was in my 80 Euro S 5 speed, but I would suspect you might be able to have the same problem with your auto. Unfortunately, as you probably know, removing the TT is not a trivial task.
Ed
you can rule out the half shafts/drive shafts and CV joints without lifting - just crawl underneath the rear and vigourously shake the shafts themselves - if they're solid and don't move they're OK, Twist them and there should be no or just a tiny bit of rotational play between the shafts and the outside of CV joints at each end of the shaft.
Bolts coming out of half shaft cvs is not at all rare from my reading of the web, especially after work being done on them (not true this time though). Test them as Jon says above, will only take a minute, and a bit of grovelling.
jp 83 Euro S AT 50k
jp 83 Euro S AT 50k
thanks for all of the responses. I'll let you know what it is....
Team Owner
I added some more info sorry i used the wrong word I meant half shaft not drive shaft please see my previous post
ooof.. I have seen your driveway... I wouldn't do that.. and im a bit on the wreckless side... Get it down on the street.. I also seen your neighborhood.. your neighbors will not put up with that for long either.... Well poop... ou can bring it here if you want. we can stick it in the garage and have at it next weekend.
Mike
ohh...not to mention. The first thing I will do after receiving liftbars is to get the thing up, check/fix A/T modulator vacuum and/or valve body adjust. Damned simple thing to do in preventing becoming a partner with TT distress, but not so simple if I can't get the car off the ground. And Considering that I may need to run a new vacuum line to the modulator valve....I can just imagine trying to explain this to the local yokel shop, and even if they did understand, I can imagine the sticker shock for a simple vacuum hose install or adjustment.
Mike
Mike
those Porken bars are high on my list too. Of all the things about the 928 that drive me crazy, the inability to easily monitor/service the tranny is top of the list.
