Intake Polishing Advice, Please......
We had a choice?
I would like to polish my intake while I have it off. I've got an 8 inch bench buffer, 1 1/2 hp@3450 rpm. What type of buffing wheel and types of compounds are needed, and in what order? I am not necessarily wanting a mirror finish, just a nice clean polished look. Thanks in advance for suggestions and help.
Anthony Tate
79/928 Silver Metallic
Anthony Tate
When I prepared my S4 Intake, found that a combination of different sandpaper grades worked best.
I spent 3 weekends smoothing out the rough areas and the pits using 220 grit, then 400 grit, and finally 600 grit. The turns/bends were a challenge, but knowing that I wanted my intake to be black, I wanted it to resemble 'black chrome'. I am very satisfied with the results.
On a spider intake, you may be able to use a buffer, but nothing beats the detail afforded by doing the polishing by hand.
Just MHO-
hth-
<img border="0" alt="[cheers]" title="" src="graemlins/beerchug.gif" />
Just MHO-
hth-
What power tools did you use Jay?
My S4 intake needs this after I, uh, put some duck tape on to hold something there during a belt check, and the paint, uh, came off with the tape....
Why polish? They'll look good for just a few months until the aluminum begins to oxidize again.
I highly recommend ceramic coating - relatively inexpensive and zero maintenance.
Here's an intake pic that sends Mr. Struthers into apoplexy
<img src="http://www.momentoffame.com/snapshots/MomentOfFame/l16753.jpg" alt=" - " />
Sharkaholic
Stop by your local Sears and pick up their polishing kit. It has three buffers and four polishing compounds, from course to fine. Just be careful with that 1 1/2 hp motor you can easily remove too much metal. I have a 1/2 hp motor for buffing and it will bog down should I apply too much pressure or if the work piece catches in the buffer. After I finish polishing I use Autosol which will remove any oxidization and help seal against further oxidizing.
Randy,
I hate it when you post that picture. I don't have my car back and those pics just bring some real fond memories back as well as the sad realization that I still do not have a working 928. <img border="0" title="" alt="[Frown]" src="frown.gif" />
Jim, think of it as being an organ donor - your car is on life support so that mine can live every day with the wind rushing through that intake, without a care in the world <img border="0" alt="[hiha]" title="" src="graemlins/roflmao.gif" /> !
Feel better now?
Feel better now?
OK Randy,
enough is enough.
I want to see a picture of your engine bay with a dated newspaper sitting beside it. Just to be sure that awesome bay is holding up to all that salty sea air.
<img border="0" title="" alt="[Wink]" src="wink.gif" />
enough is enough.
Randy,
You did it again...
Thou shalt not covet thy neigbors intake.
You are lucky that I'll be tinkering with the alternator/charging system and irritating my kids during spring break next week or I'd .........
John S.
Did I mention it still looks hot?
You did it again...
John S.
Somewhere beneath all that plumbing lies my 86.5 V8! I have planned to pull it this spring and maybe do a powder coat a la' "Bernie", but I like the look of the polished tubes as well.
Can I polish off the current factory finish which isn't too bad, except for a few flaked spots and what looks like chewing gum baked to 450 degree F, and expect to find something similar to what Randy posted? What about the cam covers?
Randy -
Please define "relatively inexpensive"!!
Also - how did you source the 'coater'...what should I look for in the yellow pages? (BTW - Ever notice in the yellow pages - "Casino" sits between "Cash Registers" and "Caskets"??? - LOL)
We had a choice?
Randy's picture is now my Desktop Background. To provide a little inspiration. I hope you don't mind me doing a little "pirating".
Anthony Tate
79/928 Silver Metallic <img border="0" alt="[cheers]" title="" src="graemlins/beerchug.gif" />
Anthony Tate
$125 - all prep included. Look for specialty/industrial coating shops in the yellow pages near you. Ceramic coating is also widely know as 'Jet Hot'.
I removed the badge and had it coated as well, then handpainted it and reattached to the intake with JB Weld.
