Is it possible to rebuilt S4+ twin fans?
#31
Tony,
The bearings are the same size as used on skateboards. Real easy. How-to and parts discussion on this thread...
https://rennlist.com/forums/showthre...ight=fan+motor
thanks
...only one bearing per fan or did i miss something?
#32
Ryan et al,
I replaced the bearings and posted a write up with pictures etc.
Just search on my name. I'm suprised johnse didn't point you to this as he helped me get the write up together.
Cheers,
Myles Garmonsway
Cheers,
Myles Garmonsway
#33
quick hit of ebay.. NSK 608V
http://stores.ebay.ca/BEARING-BARGAI...QQftidZ2QQtZkm
I bet i can go down to the sporting good shop where i get my roller blade wheels and find a set?
#34
Yes, one bearing per fan. The rear is a bronze bushing which should be fine.
The roller blade shop bearings will fit, but you really need the high temperature bearings, otherwise the grease will degrade very fast.
#35
thanks for the memory Myles - I had to read the other thread to work out what I helped you with - glad it worked out.
#36
I was looking at these for example? they are sheilded but do they have high temp grease?
http://cgi.ebay.ca/10-608-ZZ-Shielde...742.m153.l1262
here is another link...
http://www.nextag.com/bearing-608/search-html
They even have ceramic ones.....plenty to choose from. Any particular ones from that link?
#37
Tony,
There is no standard on bearing notation. Every manufacturer has there own notation, so you need the manufacturer's catalog to know for sure of the bearing application, including bearing grease.
The eBay listing for the bearing I used is on the other thread. Look at post #13 where I state what the seller stated to me by email. I had sent him the notation (post #9) and took his advise.
Ceramic is quite pricy.
