928 Forum 1978-1995
Sponsored by: 928 Specialists
928 with Cayenne engine??
Old 08-16-2007, 02:49 AM
LndShrk
LndShrk's Avatar
Default 928 with Cayenne engine??
I've been thinking lately about what I want to do with my OB to make more power, and the question that came to mind was could my old bugger be fit with the 4.5L from the Cayenne? I know it would require a new harness and possible/probably a new powertrain, but could the engine fit. I'm curious because of the awesome out put of that 4.5.
Old 08-16-2007, 02:51 AM
Aatos
Aatos's Avatar
Too high I think?
Old 08-16-2007, 02:54 AM
RyanPerrella
RyanPerrella's Avatar
dosent fit, its too tall
end of discussion
Old 08-16-2007, 03:43 AM
3000teeth
3000teeth's Avatar
First... you don't have an OB. OB's are pre-1980.
Second... why?
Old 08-16-2007, 04:27 AM
LndShrk
LndShrk's Avatar
First off I apologize for my mistake calling my car an OB. I was under the impression that it refered to all 928's before the S4.
Mainly I ask the question out of pure curiousity, because I was tinking the implication of a more modern/ current engine would allow for more sources in the peformance enhancing category. The Cayenne came to mind because, well, is got a V8. Plain and simple. It puts out 450hp stock and the turbo model is 560, I think. Just trying to think of a way to get a whole lot of into the somewhat lacking U.S. spec 83'.
Old 08-16-2007, 07:33 AM
Mike Frye
Craic Head
Mike Frye's Avatar
I'm with you on the OB thing, I think there is some disagreement on what truly is an OB. I thought the OB referred to the pre-S4 body style too.
Don't think you're the only one.
With regards the Cayenne engine, oh well. It was an interesting idea, hell if people are putting 350 Chevy engines in these things you'd think it could be done, but I guess the setup is all wrong because the Cayenne engine wasn't designed to sit low like the 928 was.
Old 08-16-2007, 08:04 AM
SwayBar
SwayBar's Avatar
The cost of the engine alone will be WAY more than what the car is worth, as well as the installation will cost more than what the car is worth.
Old 08-16-2007, 08:25 AM
linderpat
linderpat's Avatar
Received 2,420 Likes on 1,312 Posts
other than front/rear spoiler package, what was difference in body before and after 1980 up to 86?
Old 08-16-2007, 08:58 AM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,229 Likes on 1,257 Posts
end of discussion
Too wide would be end of discussion. Too tall is can be worked around.
This is argument again.
Second... why?
Why not?
If you have the means, go for it. It beats using a Chevy engine!
I surpassed the value of my OB (it's an 81) with routine maintenance. So at this point it doesn't really matter anymore.
Old 08-16-2007, 09:58 AM
cobalt
cobalt's Avatar
Received 2,262 Likes on 1,342 Posts
Originally Posted by LndShrk
. Plain and simple. It puts out 450hp stock and the turbo model is 560, I think. '.
Turbo puts out 450hp 460 ft pounds torque stock. With ECU upgrade it is bumped to 520hp and 530 ft pounds torque. This is the 4.5 liter TT.
It would not fit but would make quite a monster if it did. My CT is as fast as my GTS with the CT weighing in 2000 pounds heavier. The CT engine is much freer revving than the GTS. Imagine what a 928 would do with that motor.
Old 08-16-2007, 10:19 AM
Imo000
Captain Obvious
Super User
Imo000's Avatar
WOW, I would have thought it would be much faster.
Old 08-16-2007, 10:43 AM
cobalt
cobalt's Avatar
0-60 in 5 sec and a 13.4 1/4 mile is not fast enough for a 5500 pound truck? It actually gets faster once moving and can gain on a 997 Carrera S from 60-130.
Old 08-16-2007, 10:53 AM
3000teeth
3000teeth's Avatar
Not sure body has anything to do with it. OB: Old Bugger.
https://rennlist.com/forums/showpost...4&postcount=26
Old 08-16-2007, 11:03 AM
Imo000
Captain Obvious
Super User
Imo000's Avatar
I’m not doubting the performance of the CT. What caught my attention that it’s as fast as your GTS. I was expecting it to be much faster and 13.4 IS much faster than a GTS, unless your GTS can mach this. However I haven't seen any that will do better than high-very high 13s.
13.4 is what an SRT10 can do. I’ve ran gains two at the local drag strip and they were both pulling consistent low 13seconds. They were only a couple car lengths behind me and that’s impressive for a heavy truck. This goes for the CT too. Very impressive for a very heavy SUV.
heinrich
928 Collector
heinrich's Avatar
Body changes:
battery box and tailpipe pins under body from 86-5 are twin with a modular rear muffler. Early 85 and earlier have a single pipe one-piece; later 85 and early 86 have twin pipes that run within a couple of inches of each other all the way to the rear muffler. Spoiler cars have rear quarter windows with black parts where spoiler goes. Trim there is wider too IIRC. More early cars have no sunroof. Few early cars have rub strips. Early cars have a bigger hump in the rear to hold the bigger auto trans, manual cars of same year have smaller hump. Pre-S4 cars have no clutch mount in firewall if they are auto.
Quick Reply: 928 with Cayenne engine??
