Trans. Problem....strange?
Hey got a problem my 84 Automatic...............when I first start the car and put it in reverse it will leave a small trail of Trans. fluid on the floor. Only when I first start out (ground is level) Now if I do the same in Drive it will not do it...what in the world is this. I figured if it was the front seal it would do it in any gear...
Thoughts...Ideas??
Brian
Thoughts...Ideas??
Brian
Thoughts...Ideas??
Brian
Thoughts...Ideas??
Brian
Yeah the car does not do this in drive............only when cold in reverse. Backed it probably 25 feet and it left a football size puddle in the garage. Never when warm and only in reverse!
Steve if its the problem you spoke of......what is a fix?
Brian
Brian
Team Owner
My 88 did this also I repaced the front pump seal O ring and the trorque converter seal and it went , What Steve said sounds like the problem
