928 Forum 1978-1995
Sponsored by: 928 Specialists
Using Colder Spark Plugs
Old Oct 17, 2008 | 12:46 PM
mark kibort's Avatar
mark kibort
20hp loss for 5 degrees retard? Louie showed a slight change in HP and its peak was pushed out a few hundred rpm. I retarded my timing 6 degrees and lost no hp but lost 15ft-lbs of torque down in an RPM range i never use, so the result was all good. I also am using the colder plug for these reasons, and they dont seem to have an issues with build up. they are a little darker than im used to, but they made no difference on the dyno.
are you saying that a 2 degree net change caused a 20 hp differnce? (you said 5 degrees lost 20hp and 2 degrees was the best HP)
mk
Originally Posted by PorKen
Try it! Plugs are cheap. Start with the 5's (coldest available in this plug). If the insulator doesn't stay white, move up to 6's.
Which way are you trying to move the powerband? Up or down? Retard is up. Retard will also reduce cylinder pressures, so you have even less chance of pinging.
I was surprised that on the dyno with my '86 (similar to GT cams), 4-5° crank retard lost 20ish HP, and strangely, the exhaust AFR was leaner. 1-2° retard made the most power. I'm running straight up at the moment, and I miss having some advance for around town. 4-5° advance is nice for more grunt at low rpms. More advance requires better gas, and plugs to combat pinging!
Old Oct 17, 2008 | 12:53 PM
no doubt's Avatar
no doubt
For casual readers, keep in mind that the pros are discussing two different types of Timing in this thread:
1. Cam timing (when intake & exhaust valves open/close)
2. Ignition timing (when the spark plugs fire)
Old Oct 17, 2008 | 01:52 PM
PorKen's Avatar
PorKen
Inventor
This is an old thread. I later realized the loss of power was due to high intake temperatures, and not the cam timing.
Old Oct 17, 2008 | 04:47 PM
mark kibort
ah ha! got it.
mk
