View Poll Results: What viscosity oil do you use?
Voters: 156. You may not vote on this poll
The Oil Viscosity Poll
#76
Supercharged
Dave-
Just as a data point, I used this same oil and after my engine got to full operating temp, I was unable to get the oil pressure above 3bar. Not saying you will have the same issues, just sayin' to watch your oil pressure gauge.
#78
928 Engine Re-Re-Rebuild Specialist
Originally Posted by Andrew Olson
Dave-
P.S. I still have your dial indicator gauge (cam timing). I forgot to give it to you on Saturday. I'll bring it next time we get together.
#79
Supercharged
Yes and no.
My analog gauge is not accurate beyond about 3 bar. At 5bar, my gauge reads 4.5bar. When I noticed the low oil pressure, I could not get my gauge past 3bar! So I presume that it was indeed a low oil pressure event.
Unfortunately, it was after this event that I noticed the discrepancy between the analogue and digital readout. I was way too nervous to continue driving the car with that condition so I switched to a 15W-50 and things appear happy, but since I don't drive the car in the winter, I'm not too concerned with the cold weather performance.
#80
I'll watch the gauge carefully. Aside from my current repair effort I've never had pressure issues, but it's always been conventional oil.
The fact that Doug Hillary is using 5w40 helped my decision (no offense Chaad...I see you use it, too).
#81
Craic Head
I don't remember you mentioning this before, did you update your other thread for people who may be looking for oil guage/pressure info in the future?
I think someone else recently had a thread about his oil pressure dropping over the course of a few weeks. I wonder if he changed it and whether or not it had an effect. Who knew that the viscosity could break down all of a sudden like that? I thought it was a more gradual thing.
#82
No offense taken, of course! I only switched myself (two summers ago) based on Doug's oil analyses and input. Based on the data and the ensuing discussions, it seemed pretty obvious to me that the 5-40 was the superior oil for my application (no racing, three season driving, short trip).
I haven't had any change in oil pressure readings (at idle or otherwise) since switching from...man, I don't even remember what I had in before.
Interestingly, I first stumbled into Rennlist when Doug was posting his fourth report or something like that, and was using 15-50 himself! I didn't yet have a 928, but I remember thinking, "Man, this site is way cooler than The Saab Net forum! These guys are serious!"
#83
Administrator - "Tyson"
The factory never ran a 928 engine with more than 220hp without a cooler. I'm running 400+ without an oil cooler plus a supercharger plugged into my oil system that could be adding even more heat into the oil. This coulc be why my car was not happy with 40 weight. I have no idea.
#84
Originally Posted by svp928
I've used Mobil-1 15-50 for 11 years, including a fair number of track days. Never had a problem...120k miles on the engine. No leaks, ticks, fleas or mosquitos.
When I bought the car there was a pretty significant (at least to me) oil dripping situation, but I could not pinpoint the location. I replaced the Mobil with plain old Castrol 20w/50 GTX, changed the filter and added 16oz of AutoRx . The manufacturer claims that synthetic oils will not keep seals pliable as will mineral oils. I have no idea if that is true or not. AutoRx supposedly cleans the crud off the seals over a long period , then allows mineral oil to penetrate & swell the seal thereby stopping the leak.
I've driven over 1000 miles with that combo & have noticed a marked reduction in oil drips under the shark. Where I'd have a little puddle about size of silver dollar, now I get a drip or two.
Anyway, that's my rationale for using petroleum oils rather than synthetic. If I knew for sure I wouldn't get a seal leak, I'd probably go to Redline.
Hawk
#86
scot is racing a 290rwhp 2 valve 5 liter part euro with a stock radiator and no oil cooler.
its running 270F temps on the oil on the hottest race days.
Ill have to put the temp guage on my engine, and see what it shows. I have 30 more hp and the radiator type oil cooler.
MK
MK
#87
Riddle me this. I was looking up the oil to use for my wife's Audi today.
In more than a few threads it has been noted the first number in multi-weight oils is cold / start up temp only.
In the owners manual of the Audi, it states:
10w-40 should never be used in ambient temps over 80 degrees
15w-40/50 should be used up to 100 degrees ambient temp
20w-40/50 should be used for any temps beyond.
I realize in Wisconsin I'm under 100 degrees 99.9% of the time. I'm puzzled because if the first number is only under certain temps, why would it matter on an 100 degree day if I was using 10w-40 or 15w-40 or 20w-40?
What am I missing here?
#89
#90
928 Collector
Hacker I think that manual info is incorrect. From the API website (suipports our understanding):
Originally Posted by API
SAE Viscosity Grade
The center of the Donut shows the oil's SAE viscosity grade. Viscosity is a measure of an oil's flow characteristics, or thickness, at certain temperatures.
The low-temperature viscosity (the first number, 5W in a 5W-30 oil) indicates how quickly an engine will crank in winter and how well the oil will flow to lubricate critical engine parts at low temperatures. The lower the number the more easily the engine will start in cold weather.
The high-temperature viscosity (the second number, 30 in a 5W-30 oil) provides thickness, or body, for good lubrication at operating temperatures.
A multigrade oil (for example, SAE 5W-30) provides good flow capability for cold weather but still retains thickness for high-temperature lubrication.
