View Poll Results: What viscosity oil do you use?
Voters: 156. You may not vote on this poll
The Oil Viscosity Poll
#61
Originally Posted by John Veninger
Not true. High mileage oils add seal conditioners.A 10w-30 is a 10w-30 in terms of "thickness"
#62
I'm not a Mobil 1 fan for one reason....in one of my 928s one of the valve lifters makes a noise when idling on Mobil 1...but goes totally away with dino. I'm guessing that synthetic must be "too thin" to keep the valves pumped up. Change the oil often and I don't see why a modern dino oil wouldn't be as good as anything. Nope...I've not tried Amsoil...for the same reason I don't run Mobil 1.
Harvey
Harvey
#63
amzoil is a different animal to Mobil 1. (only in respect to what the oil pressure is when hot, which could be the reason for the lifters not pumping up)
i totally agree that some dyno oil, changed frequently, does do the job. Im starting to remember a test that reallly swayed me away from dyno oil
mobil 1 after 1000miles vs kendal 20/50 and then the qualities of amzoil and redline at 5,000miles. the kendal was equal to the others after 1000miles , but degraded quicker with age. mobil 1 was the worst of the bunch, especially after 1000miles. thats when i figured change the oil every 1000miles with kendal (during race use) and 3000 miles with amzoil or redline. cost equaled to be the same in the end
MK
MK
Harvey
Harvey
#64
or real life experiences.
what we need is a test of the oils at 280F!
mk
mk
Originally Posted by Larry928GTS
And interestingly enough, the majority of the people responding to the poll are disregarding those recomendations.
#65
I used to use first press virgin (ain't that a misnomer - can't be virgin if it is second press) Now I only use Extra Virgin - all those extra virgins to squeeze mmmmmmmmmmmmmm.
Can't we use Castrol R - I love the smell of that stuff.
Extra Virgin Castrol R - Heaven.
#66
Owns the Streets
Needs Camber
Needs Camber
Castrol. Wasn't that fresh pressed Castor Oil?
Excuse me miss, are you a virgin?
Synthetic and nubile wimmin has totally different connotations. (They do test for siilcone in oil analysis from the one's I've seen)
#67
Man of many SIGs
I am appalled. The poll results have been faked and Jim M. has comitted voter fraud by voting twice. I demand a recount, and a choice for 0w-40.
#68
Originally Posted by Fabio421
I am appalled. The poll results have been faked and Jim M. has comitted voter fraud by voting twice. I demand a recount, and a choice for 0w-40. ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
H2
#69
I've used Mobil-1 15-50 for 11 years, including a fair number of track days. Never had a problem...120k miles on the engine. No leaks, ticks, fleas or mosquitos.
#70
I heard that all the newer Porsches are designed for the lighter oils......like 5-40.....if you put a 20-50 weight into them it messes up the variable valve timing...since it is oil driven....& very sensitive to oil weight....my 06 Acura uses 5-20W....that stuff has gotta be like water!!
I previously used Mobil 1 15-50...& had no problems with it...but just switched to Amsoil Racing 20-50 (Amsoil does make a standard 20-50).....do I notice any difference.......not really......since I haven't got the engine hot enough yet to tell....but it does take longer for the oil to heat up and start dropping pressure at idle...but it does stay .5 to 1 bar higher at idle than the M1 did....typically the M1 would be 2-2.5 bar warm at idle vs 2.5-3 for the Amsoil....
#71
Owns the Streets
Needs Camber
Needs Camber
How'd you keep the 5W-20 from leaking past the plastic bottle seam, Brian?
Guess all the fuel mileage concerns has manufacturers chasing the least engine internal resistance.
#73
#75
928 Engine Re-Re-Rebuild Specialist
![](https://img410.imageshack.us/img410/5893/worfisfrustratedxc4.gif)
Thanks for all the replies. I picked up some Rotella Synthetic 5w40 at Wallyworld. It's the first time I'm using synthetic in the 928. I intend on driving the 928 during the upcoming cold Michigan winter, so I'm not comfortable using a 15w or 20w viscosity.
