Where can I find Door Window Seals
I called a couple places and was told that they have to order from Germany. Anyone know where to get them here in the states?
These folks have them on eBay regularly. They sell them for as little as $94.95 per side, but they have been slowly raising the opening bid.
http://cgi.ebay.com/ebaymotors/Porsc...29311757QQrdZ1
http://cgi.ebay.com/ebaymotors/Porsc...29312357QQrdZ1
Rod
Rod
There are two different versions of late style soft seal. In '91 MY new lip was added to seal so that it will wipe off rain trops from car body around door opening when door is opened. In practice new style seal will probably make inside ever so slightly quieter place. Might be good idea to try to find both types of seals if you want them quickly. Though only latest type is probably available.
Hi Rod,
I actually need the seal that the door windows slide up into. I thought they are called "door window seals".
Here's the part numbers for Lt/Rt:
928 537 32303
928 537 32403
928 537 32303
928 537 32403
Rod
Rod
Thats an expesive date.. Kepp us posted. Mine still look good at 4 feet. But I think they only have anohter year of life in them, maybe two now that shes in a climate controlled garage.
I had to get a fuel pump from sunset for the car. It was in germany and typically takes 3 weeks from Porsche. They had a quicker option, I paid 15% on top of the price of the pump and get it sooner, was told about a week. The damn thing got to oregon from Germany quicker then the part in Ontario got o them by 2 days. So thats an option if you need it fast and want OE parts.
Let us know what prices you get for those outer rails, i could use one or both. Last time I checked they are about $100-$150 each.
Team Owner
to make your door window seals last use Dow Corning 111 silicone grease the same stuff you can use on O rings just wipe on the seal with your finger and let it sit , careful not to get it on the window as it will make streaks when the window goes up and down, also use this same stuff to lubricate the new seals when installing them they usually will slide into place with little effort, and a small plastic push bar,
Basic Sponsor
I normally sell those for $159.95 each but have non in stock.
For the 323 03 there are 2 sitting at dealers in the US and non in Atlanta and non in Germany.
For the 324 03 There are non in the States including Atlanta but 103 in Germany.
Try 928 International or 928 Specialists as they may have some in stock.
Good luck.
Good luck.
Mark got me mine from Germany , no sweat, got it yesterday...
or try Sunset Porsche too, but support Rennlist vendors first always.
Jeffclark@sunsetimports.com that is the parts guy.
Originally Posted by Darien Nunn
Hi Rod,
928 537 32303
928 537 32403
928 537 32303
928 537 32403
Rod
Alright, what are those prices converted to US currency?
Originally Posted by dan davies
