928 Forum 1978-1995
Sponsored by: 928 Specialists
42# Injectors - Which ones?
Old 07-09-2007, 04:02 PM
AO
Supercharged
AO's Avatar
Default 42# Injectors - Which ones?
I'm looking to get some 42# injectors. Can anyone tell deffinitively which ones I should get from Summit Racing?
They have this "Summit Brand" for $299 for a set of 8.
Or I could get this "Ford Racing" set for $399.
Thanks for the help.
Old 07-09-2007, 04:05 PM
AO
Supercharged
AO's Avatar
Whoa! Just noticed the dimensions are different for these. Looks like I won't save the $100 afterall.
Old 07-09-2007, 04:17 PM
Mike Frye
Craic Head
Mike Frye's Avatar
Silly Andrew, You should know by now that if it's cheaper, it's the wrong part.
Old 07-09-2007, 04:27 PM
AO
Supercharged
AO's Avatar
Ain't that the truth...
Old 07-09-2007, 04:40 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Well the Summit units are “GM” style and the Ford are the “Bosch” style. Just because they look different, it doesn’t mean that the top and bottom diameter and the overall lengths is different. The Gen III & IV injectors look different too but from what I understand they physically fit into the factory rail. The electrical connector needs to be changed, but other than that they are a direct fit so this might be the same with the GM units. What you need to be sure of, besides the vital dimensions, is if they are the same impedance as the OEM injectors.
Old 07-09-2007, 04:46 PM
AO
Supercharged
AO's Avatar
DR told me to get the "11-14 ohm" set but I think he meant the 11-18. I'm pretty sure the Ford Racing set is what other use. Pretty interesting that they give zero warranty. Hmm. Maybe I should check ebay. Bet I can save $50+!
Old 07-09-2007, 04:53 PM
Scott M.
Rest in Peace
Scott M.'s Avatar
Have you checked with RC Engineering?
Old 07-09-2007, 11:28 PM
Koenig928
Koenig928's Avatar
Hey Andrew,
Yes, these are the ones to get. Looks like they went up $20 since last year.
FMS-M-9593-F302 FUEL INJECTORS A Shipped on 09/28/06 $379.95 1 $379.95
Just need to move the bottom o-ring over.
Old 07-09-2007, 11:33 PM
AO
Supercharged
AO's Avatar
Thanks Bill and others. Abby is going to sell me a set he recently purchased but cannot use. The price is definitely right.
Old 07-10-2007, 12:13 AM
FlyingDog
FlyingDog's Avatar
FYI stock should be around 14.5, but the spec has a wide range. I think as long as they don't vary much from one to another, you're fine in that range.
Old 07-10-2007, 03:08 AM
atb
atb's Avatar
Andrew,
New does not equal balanced. If the car doesn't run right with them in, send them out to get calibrated.
Old 07-10-2007, 09:35 AM
AO
Supercharged
AO's Avatar
Originally Posted by atb
Andrew,
Adam-
I beleive it is a myth that injectors can be tuned or balanced. To my knowledge, you can only clean them to achive optimal flow.
AFAIK, the only way to get a flow matched set is to start with a larger pool of injectors and then select ones that have the same flow characteristics. However at the price that I'm getting these, if I had to buy an additional 2-3 injectors, I'd still be ahead of the game.
Old 07-10-2007, 10:16 AM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Adam-
Yup, that's how I know it too!
Old 07-10-2007, 12:01 PM
atb
atb's Avatar
News to me. Good to know.
Old 07-10-2007, 12:06 PM
Mike Frye
Craic Head
Mike Frye's Avatar
I read that somewhere too. You might need to get more than 2-3 extra though. Maybe check with a company that does the injector balancing and see how many spares you'd need for a good flow match?
Quick Reply: 42# Injectors - Which ones?
