C/V question
Hey all I am replacing the right rear axel in my 84 928. How many gaskets do I need for the connection to the rear diff. 1 or 2
Brian Felts
Brian Felts
Two - one on the flange holding the boot and one on the flange of the dif. body you're bolting the C/V joint to. Good luck, messy job, BTDT.
o(_)o -- J.S.
'79 O.B. - A/T
o(_)o -- J.S.
'79 O.B. - A/T
I don't know what year they changed, but if the hub end looks like this you will need four:
![](https://members.rennlist.com/sharkskin/Pages_SA_R05-HalfShaftInstalledHub.jpg)
Later cars had the hub end welded together instead of bolted and only require two.
Yes my hub looks just like that, I figured one for the bold side one for the diff side. Do I need anything to go out on the axel? I believe its sealed
Brian
Brian
