FS: Stroker crank
#35
Originally Posted by marc@DEVEK
stock one works fine for motec ... 60-2, so does the cam sensor I did it on two 928s already
#37
Both the rods and crank seem to me to be bargains, I bet you that there are a few people out there that have strokers wishing they had got a deal like this. Marc who made the rods and what bolts do they have?
Greg
Greg
#38
I hate to even ask this question, but with the crank and ti rods, what piston options would there be if you wanted to end up with a low compression blower motor.
Ken
Ken
#41
The Parts Whisperer
OK the Oliver rods are also available for $1k so for $3k you get the Scat crank (8cw) and Oliver rods. It was balanced with the JE piston but you could use the 968. That would require weight be added. I've also got a set of used 968 pistons for $1k.
#44
