928 Forum 1978-1995
Sponsored by: 928 Specialists
DLC coating
Old 05-23-2007, 04:09 PM
BC
BC's Avatar
Default DLC coating
I wanted to do this but have run into 2 issues.
1) They only do NEW parts, not used ones.
2) They cost 32 dollars a lifter. 32x32 is a 1024 price tag. Ouch.
The reason was I am using stronger springs and a slightly bigger cam, and will go to 7,000rpm for various reasons on occasion.
I guess I could just do swain coatings, but they are more sacrificial.
Old 05-23-2007, 04:18 PM
BC
BC's Avatar
I talked to swain and they said they don't like doing hyrolic lifters, as contaminants could get into them.
I guess I will just polish them to a very high shine and slather on the assembly lube good and thick.
Old 05-23-2007, 05:25 PM
6.0-928S
6.0-928S's Avatar
Hi Brendan,
Are the cam & the lifters both used?
Hammer
Old 05-23-2007, 06:13 PM
hans14914
hans14914's Avatar
Why not get some nice light-weight solid lifters fabbed up? With all the work that has gone into your project, it may be cheap insurance. Sure you have to shim them, but they will accept the coating, and never bleed down high in the rev range. Just an idea. I had Kent and Arrow both quote a set for my audi stroker a couple years ago, and dont remember it being that bad. Albeit the exchange rate has gone to pot. I dont know of any good american lifer shops though.
Hans
Old 05-23-2007, 06:27 PM
BC
BC's Avatar
Hans
I may do that for the stroker. I will want to spin that thing high. This engine is just a warmed over 5.0L with arp bolts and studs on everything, drilled crank, and will get some boost.
BC
BC's Avatar
Originally Posted by 6.0-928S
Hi Brendan,
Hammer
Correct. 86 cams, cut for the S4 heads, and the lifters are original.
Old 05-23-2007, 06:41 PM
hans14914
hans14914's Avatar
Since hammer had success on the ati damper group buy, you may have luck with the same guys for solid lifters. If i had a choice, i would go with Arrow. No doubt they make the best in the business. Plus, they offer a DLC coating option, also micropolishing... etc. I am sure you already know, but here is the website if you are feeling lazy,
http://www.arrowprecision.co.uk/
Fantastic rods, lifters, and lash-caps. If I could afford to use them on every project, I would.
Hans
Old 05-23-2007, 06:56 PM
RyanPerrella
RyanPerrella's Avatar
Ive had DLC (Diamond Like Carbon) priced out by a firm in China or Japan before and found it allot more reasonable then it was here in the states. That was 3-4 years ago mind you. But I would try another supplier.
I would agree though that your better off with a lighter lifter then with a lower friction surface on the ones you have. The Porsche lifters are pretty big and very heavy.
Old 05-23-2007, 07:10 PM
BC
BC's Avatar
Then I will go in that direction probably - for the big engine. I wonder how the shimming would work.
Old 05-23-2007, 07:33 PM
Mike Simard
Mike Simard's Avatar
Hans
I would be interested in some lash cap adjustable tappets if someone wants to initiate it, we would also need a bunch of 7mm stem lash caps. The body size is 35mm and that's used in other applications like VW and Alfa.
Old 05-23-2007, 07:51 PM
BC
BC's Avatar
SO the check would be with the cam covers off, but to actually change the lash it would be with the cams off?
Old 05-23-2007, 07:58 PM
V2Rocket
Rainman
V2Rocket's Avatar
According to Performance Products, entirely new valves would be $40 apiece.
Old 05-23-2007, 08:02 PM
BC
BC's Avatar
New Lifters is what we are talking about, but for valves, I think some of our sponsors have them for in the low 30s.
Old 05-23-2007, 08:08 PM
Mike Simard
yeah, it takes adjusting the valves to a new level, you have to really be into it
The other way, like a VW, is to compress the lifter at the edges and slip a big ole shim into place. That style is easy to adjust but heavy, like having a manhole cover sitting on top of the lifter ready to flop around as soon as valves start floating. The shim under the bucket (lash cap) style does require removing the cam to adjust but is the lightest possible lifter. As long as the valve seats and valves have good mating surfaces, valves shouldn't need frequent adjustment. One advantage of lightweight valve train components is that you can use lighter spring pressures which benefits the whole valvetrain from the timing belt to the valve seats.
Old 05-23-2007, 08:21 PM
BC
BC's Avatar
Cool. I'm thinking cut down base circles from S3 cams anyway, so I will have custom stem lengths. May as well go all out on the solids. 7L, Solids, Big valves. Cool.
Quick Reply: DLC coating
