So...what's the best way (if any) to check/fix an idle stabilizer?
928 Engine Re-Re-Rebuild Specialist
I've seen several discussions on checking and servicing the idle stabilizer valve to remedy "lumpy" or "hunting" idle problems.
While I've got my engine apart I figure it's time to at least make sure mine is working properly since my idle was fluctuating up and down. What's the best (and safest) way to check the ISV for proper operation? What's the best way to clean it while it's out?
Administrator - "Tyson"
In the scope of this project, how much is a new one? Not much - just replace it
Originally Posted by H2
I replaced mine...only to find that I had overlooked a vacuum leak.
Harvey
Harvey
Originally Posted by Big Dave
But that doesn't answer the question. What if it's not faulty?
No wonder my parts box in the garage needs it's own stall.
...which is a mistake I don't want to make (i.e., replacing parts that don't need replacing).
Originally Posted by Jim bailey - 928 International
New is less than $140
So...anyone care to answer the original questions?
Then you have a spare!
I already have too many parts taking up space.
Audi Coupe's are known for faulty idle/ air valves. We test those with a 9-volt to see if it's opening / closing all the way.
You can look at the brushes on the motor, you can clean lube it with wd-40 / carb spray but there is no real procedure to bench test it.
If you are lucky and it's a gummed up valve, you can inject a quality lubricant like LPS into the air lines to the idle stabilizer and that will free the unit up to normal function. This has worked great on 2 928's I've had. I've got this 88S4 that needs the throttle part open for starting, and the idle isn't so great. The lube procedure did not work.
Ok,
Here is a noob question.
Where is this ISV located?
Received 1,607 Likes
To test the ISV: Middle pin is 12v. Hit each of the other pins with ground one at a time. You should see/hear/feel the innards of the ISV move smoothly and quickly.
