928 Forum 1978-1995
Sponsored by: 928 Specialists
New Product: Upper A Arms for Late Model 928
Old 10-08-2007 | 10:59 PM
  #106
BC's Avatar
BC
So you are just planning on large fine thread bolts in place of the studs that go through the engine compartment wall?
Old 10-09-2007 | 12:30 AM
  #107
Lizard928's Avatar
Lizard928
Carl, I will install and take pics if you want, I sent you an email as per your request as well.
Let me know when you want to send them and I will get it done asap.
Colin J
Old 10-09-2007 | 11:29 AM
  #108
Carl Fausett's Avatar
Carl Fausett
Developer
No. We re-use the factory mounting studs just like you do when you replace the a-arms. The mechanic will thread the nut back onto the mounting stud and pound them backwards out of the mouting crossbrace. Then the mechanic will press or pound them into the new upper a a rm crossbrace, and re-install into the car.
It is a procedure very similar to replacing wheel studs.
Old 10-09-2007 | 11:42 AM
  #109
Carl Fausett
Developer
How strong are they? Any testing or modeling?
I'm not welding them up here in my little shop, if thats what you're thinking.
The manufacturer that I have making them for us has been making suspension components for racing cars for 30 years. These bearings and this manufacturing system has been in use for many many years. Only the dimensions are unique to fit the 928. The bearing (ball joint) is an Aurora Bearing COM 12 unit.
No need to re-invent the wheel I figured. You go with what has been working well for a long time.
Old 10-29-2009 | 04:26 PM
  #110
hans14914's Avatar
hans14914
Carl,
I remember reading about an upcoming upgrade to the ball-joint used in these arms in a suspension thread over the summer - any details on the modifications? Will the joint include a boot?
Thanks,
Hans
Old 10-30-2009 | 04:41 PM
  #111
Carl Fausett
Developer
Hans
Good timing! We just finished the re-design and have them available now.
Please follow this link to the new post:
https://rennlist.com/forums/928-foru...ml#post7032483
