CRACKED CAM GEAR???
I decided to fix my oil leak which appears to be from the drain back port of the distributor drive on the L/S head. While looking around I found cracks in both of the cam gears.
I guess my questions are.
Is this common?
What is the cause, if known?
Where do I go from here?
The pic shows the L/S But the right is the same.
Thanks for your input.
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Is this common?
![](http://forums.rennlist.com/upload/cam_gear_crack.jpg)
Inventor
Both gears? Weird. Was the car ever hit in the front?
Perfect time to upgrade to 32V gears?
obviously you should replace them with new ones.
I am curious as to how they cracked though. I havent heard of that before. And youve got 2 hat are cracked.
Would love to hear thoeries on how this happened
Under the Lift
Can't recall any previous reports here. A number of cracked cam noses, cracked cam spiders, but not the gears. Wonder if it was overtorqued. Should be 47 ft-lbs. See how much it is when you replace it.
I had a cracked cam spider that led to a complete cam failure. I would replace both the cam gears and spiders immediately before restarting the car, no matter what else anyone told me.
I don't believe that the car was ever hit. I don't see any other damage.
The Cracks don't look like the open up nor do they look fresh.
I put about 100 miles on it on Sunday and the only reason why I went digging is because my air pump bearing went bad.
Tell me more about the 32v gear update.
What is the purpose, benefit and cost?
+1 on that. Change those spiders--if the gear is cracked, they are probably damaged, even if not cracked themselves.
Jim
Is repairing a cracked cam nose possible? I've not heard of this potential problem before.
Harvey
if you are going to replace them, do us a favour. Tab it lightly with a hammer and post the pic or maybe the video when it breaks. I don't think it needs much force to break those cam gears.
