A Stupid Questions (Which wheels spin)
Administrator - "Tyson"
Originally Posted by Charley B
Only if the A/C in on.
Team Owner
Better get Geico!
They can be. but then again, then they could be spining slower too.
Originally Posted by Stevestik
When the back ones are not spinning more than the front ones, they are spinning just as much as the front ones.
Yes! Because "rate" implies a measurement of something over time, and I am also assuming that the front and rear wheels are both of the same diameter, but the tires are of a different aspect ratios, the front wheels spin at a lessewr rate when you are driving normally. However, due to the fact that 928's have more than ample torque throughout their power band, the reverse may also be the case. Well, unless you're going in reverse.
Dean of Rennlist, "I'm Listening"
If an airplane is taking off on a very long conveyor belt...
