Shark Roast
Shark Roast
I guess my heater valve is out and my shark is trying to cook me alive
I just drove about 20mi to go pick-up my GrandPrix tickets and on the way back I started Cookin.
Question ?? If your handy with a wrench how long does it take to replace the heater core valve? Anyone? I would have to do it tonight cuz The grand prix thing has to happen and Im not goin in the Ford.
Under the Lift
30 minutes.
Pop off the air filter top and base.
It's right there near the fuel pressure regulator on the passenger side at the rear of the motor.
Before you replace it, check that it is getting vacuum and closes (arm pulls back) when you start the motor. If not, you can temporarily wire it shut. Here is Tony's way of doing it. You only need to do step 1.
http://members.rennlist.com/v1uhoh/summer.htm
Also, these valves can fail internally, so that even if the arm moves, the guillotine style valve does not hold back the hot water. In that case, you would need to replace the valve. There is a NAPA supposedly all metal (inside as well as outside) replacement, but I just use the stock valve as they seem to last 15+ years.
If you replace it, you will lose a fair amount of coolant. So have a gallon handy and refill the reservoir with a 50/50 mix while running the motor until it gets fully warmed up and with the heater on.
The short hose from the block to the valve is a WYAIT item. It's odd size, so you will need to get that from one of our favorite vendors.
thanks for the reminder. mines works intermittently, sometimes its fine, and other times its pumpin heat when you dont want it. now i have my next project.
i also assume it is NOT normal for air to always be coming through the front defroster vents, even when all of the vents are closed in the via the front register control and the fan set to zero.
If the valve is not closing with motor and air on you can route the vacuume line ahead of the one way valve located near the brake booster. Use a T and vac hose works fine as a patch. If you connect it ahead of the valve off of the booster every time you get on the car the vacume will drop and you will get hot air.
Under the Lift
Oh, I just remembered John Pirtle's excellent guide on this...
http://members.rennlist.com/pirtle/svc_act.html
And he has a super guide on the heater valve.
http://members.rennlist.com/pirtle/svc_heatv.html
Jeez, I could have saved a lot of typing keystrokes.
I just pulled my console out recently to R&R the interior vac system. The orange line to the comb flap was completely disconnected from the "switching" manifold. That explains why the lower center vent blew all the air and the upper center vent was very low on airflow. Me and my passengers would always fight for the lower center A/C vent. The blue line to the fresh air flap (under blower motor) holds no vacume. This vacume pot is shot, or the line is disconnected. The combination of both of these vacume leaks would not allow anything to work. The hot water valve would not fully close, the fresh air door stayed open allowing in hot outside air, and the center comb flap stayed shut. It is a miracle that I got any cool air at all.
The defroster flap "sticks". It will open with a mighty vac, but it takes several pumps before it will break loose and open up, and then it holds vacume fine. I thought I could hear a hissing noise from behind the pod, but I think it was the orange line that was making the hissing.
Make sure the new one is installed in the correct orientation.
Many times that valve gets installed backward which causes it to not seal properly when closed.
Look for the arrow on the valve body. Coolant flow is from the engine towards the cabin.
John,
The mystery man in the photo is me. I was at the river walk in San Antonio and me, my stepson and his friend all bought these "wrestler" masks. On our way back home, we put them on and my wife snapped the pics.
Originally Posted by Bill Ball
That was too easy!
yea, i'm just waiting for some bizarre side effects . put 200 miles on her today including a sprint up to 130 .... not a hiccup!
