928 Forum 1978-1995
Sponsored by: 928 Specialists
Installed my New Single DIN Navigation Head Unit! It's Sweet!
Old 04-20-2007, 11:54 AM
AO
Supercharged
AO's Avatar
Originally Posted by Alan
Andew - even although you don't have that relay it is still wired and has an installed bridge connected to plug U11 - this is just the fused supply to the back of the car to the reverse switch on the transmission - that directly drives the reverse lights on a manual. There is a connector to the switch behind the plastic cover above and in front of the battery compartment in the spare tire well. This is the furthest forward place you can connect to it..
Its a 2 pin connector with a Blue & Brown wire one side and a Blue & Black/Blue the other - you need the Blue ones - they go to 12V when reverse is active. I know its a pain... how do you feel about taking out the passenger front & rear seats & lifting passenger side carpets for the shortest & neatest run.. (Not what you wanted to hear I'm sure....!)
Alan
Thanks Alan... It's not that big of a deal. I'm going to have to pull it anyway when I install the camera, so I'll just do it then. I was just hoping I could do it all at the CE panel. Thanks anyway. BTW, your primer is proving very useful - I just need to learn how to read relays one of these days.
Old 04-20-2007, 11:57 AM
fabric
fabric's Avatar
Andrew-
I just saw this in Crutchfield and thought "That's perfect!" Looks good in the car, and you got it for way less than Crutchfield wants.
For the auto dimming, you may be able to hook it up to the light in the ashtray. That was what I was going to do for mine, but my light doesn't work. Or I got lazy, I can't remember which. In either case, i'll be interested to hear how you sorted that out.
Hmm, under $700, this might be moved up on my list. I'm getting spoiled by the GPS in the 540, and I'm not really a fan of the Alpine I have now.
Old 04-20-2007, 11:59 AM
0utlier
0utlier's Avatar
The GPS antenna should work fine inside the car, and of course will be more aesthetically pleasing and stealthy. My Sirius antenna is another story though. I've tried putting that thing everywhere in the car and it just doesn't reliably pick up the signal. So back on the roof it went. Very irritating. Nice new toy by the way.
Old 04-20-2007, 12:03 PM
fabric
fabric's Avatar
Hey Andrew - is this thing a removable faceplate?
Old 04-20-2007, 12:06 PM
Art_Z
Art_Z's Avatar
Originally Posted by Courtshark
Is that a DIVX logo I see? I thought that service was long gone.
this DIVX is a video encoding format, no to be confused with the failed launch of a competing DVD pay per view platform with the same name some 10 years ago.
Old 04-20-2007, 12:08 PM
Alan
Electron Wrangler
Alan's Avatar
Andrews - you said
" BTW, the speed sender for 1991 is P15, not F15 as Alan had guessed."
Actually it wasn't a guess - I was quite certain of this because I looked at the diagram and had already done it myself...
Oh well - turns out its just that my eyesight isn't what it was (be very worried...).
I'll promise to put the new reading glasses on from now on when spelunking in the wiring diagrams...
P15 / F15 - whats the difference!
Alan
Old 04-20-2007, 12:19 PM
Alan
Electron Wrangler
Alan's Avatar
Mike - The Auto is really easy (at the central electric panel) - the manual is the hard one. I have mine wired as I described to Andrew for both my Sat Nav and rear-view auto-dim mirror. Its a bit tedious but really not that hard.
Certainly I'd do it this way this over adding switches on the shifter - its really not that bad...
Alan
Old 04-20-2007, 12:25 PM
heinrich
928 Collector
heinrich's Avatar
DAMN that's hot. Stick the antenna to the glass though.
Mike Frye
Craic Head
Mike Frye's Avatar
Oh, I thought Andrew had an auto for some reason. Didn't really look.
And as he said, he's going to be running wires back there for the camera anyway sooo.... Nevermind.
Old 04-20-2007, 12:35 PM
Mark
Mark's Avatar
AO - The illumination is easy....hook up the wire to the HVAC light lead...
Old 04-20-2007, 01:23 PM
AO
Supercharged
AO's Avatar
Yes!
F15 = No worky
P15 = Worky!
Thanks... the antenna is magnetic, but based on the advice here, I think I'll put it inside on the A-pillar.
Great idea! Ash tray doesn't work as it's on all the time (tried that with the last head unit). But you're right, this should be very easy!
Old 04-20-2007, 03:17 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
I like it too.
Old 04-25-2007, 01:48 AM
RyanPerrella
RyanPerrella's Avatar
Andrew,
Is it me or does the face not sit flush with the rest of the center console? It looks like it sticks out 1/4"-1/2". But I also noticed that the Alpine in my car isnt flush either.
There isnt anyway to change the backlight color is there? I know some head units you can change the illumination color to match the OE instruments, wether they be blue, green, amber or red.
Old 04-25-2007, 02:28 AM
Nicole
Cottage Industry Sponsor
Nicole's Avatar
I like it, Andrew! This unit goes quite nicely with the 928 interior.
This unit is currently on overstock.com for more than you paid - I thought some time ago I had seen it or a similar one there for about $400, or maybe $499. Was probably refurbished, though.
Old 04-25-2007, 10:45 AM
AO
Supercharged
AO's Avatar
Originally Posted by RyanPerrella
Andrew,
The faceplate does stick out about a 3/8". Removed, the unit sits flush. I don't think you can change the LED color, but then I haven't played around with it too much. I know you can change the map colors on the LCD screen.
Really? That's weired! This unit was just released by JVC. They did have a DVD unit that looked similar, but did not have the NAV or the HDD, and I think that sold for about $400-$500. Maybe that was what you saw?
Quick Reply: Installed my New Single DIN Navigation Head Unit! It's Sweet!
