fuel rail fire up relay by passed no action.
86
I removed xx fuel pump relay and inserted pins to connect 30 and 87 reconnected the battery and jumpered clips no noise am I doing something wrong. The ign switch is off I was told to test it this way to look for leaks.
Mark
Mark
Under the Lift
Check fuse 42. If you have correctly jumpered 30-87 on the FP relay's CE panel cocket and the fuse is good, the FP should run as long as it is jumpered. If not, there is a problem in the wiring to the FP.
Under the Lift
Originally Posted by Fabio421
There was a thread I remember that said there are actually two pin # 87's and they need to both be jumped.
I found info on testing, it said to turn the key on but don't start the motor. I do not hear my fuel pump turning on can you be more specific?
Administrator - "Tyson"
Originally Posted by Bill Ball
I believe that's just on the old boys.
Fuse is fine I replaced the relay turned on the key did not start motor ,is not complete together sensors off plug wires off ect. When does the relay active is it while it is in the start mode, then stys on ? What could be disconnected to cause this I did an intke refresh there is not a lot to remove cable wise.
Under the Lift
Originally Posted by Hacker-Pschorr
I only need to jumper the two on my 81 to fire up the fuel pump
Supercharged
I believe (could be wrong) that the FP relay does not activate until there the LH picks up the impulse from the Flywheel (just not sure if the 86 has an impulse sender or not.) If this is comprimised, you will not get fuel and you will not get spark.
Under the Lift
Anyway, unless you have a ground wire off or power to the battery disconnected, the FP should run all the time if the you have jumpered its relay socket 30 to 87.
Check that 30 at that relay socket is hot (12V). If not, then the battery is not providing power for some reason. If it is hot, then go back and look at the fuel pump leads. Test that it is getting 12V on the power lead and that the ground wire has continuity to ground.
Under the Lift
Under the Lift
Right, but my understanding is that he is just trying to pressure up the fuel rails. He doesn't have plug wires or sensors connected, so I assume he doesn't expect the motor to start.
Note to self do not use paper clips as a bridge. I took off a factory jumper that replaced a relay next to it and the pump fired up. My ? is how long do I keep it on to pressure up the system. I did about 15 sec no leaks feed back please and thaks for the help
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
