928 Forum 1978-1995
Sponsored by: 928 Specialists
4v heads on 4.7L??????
Old Apr 10, 2007 | 07:42 PM
Fabio421's Avatar
Fabio421
Man of many SIGs
Default 4v heads on 4.7L??????
Please forgive me if this is the most rediculous question asked in awhile. I am assuming it has been thought of and doesn't work. It never hurts to ask. I have never had the oportunity to really look at an S-4 engine.
I know that the blocks were the same throughout the years although bored out as the years progressed. Is it possible to upgrade a 4.7L to the 4v heads? Are the intake ports in the same location/ If so are the bolt patterns the same? I know the exhaust pattern is different.
I am not inquiring about the engine management, only if its possible to swap heads and exhaust.
Old Apr 10, 2007 | 07:49 PM
Jim bailey - 928 International's Avatar
nope
Old Apr 10, 2007 | 07:59 PM
Vilhuer's Avatar
Vilhuer
Blocks are not the same. 4.5L and 4.7L have smaller bore average outside diameter than 5L and 5.4L. Still, it should be possible to install 100mm pistons into old style blocks. Its just like making 104mm stroker from 5L or 5.4L. Some blocks do not have enough material in them while others have, barely.
Old Apr 10, 2007 | 08:04 PM
Fabio421's Avatar
Fabio421
Man of many SIGs
Originally Posted by Vilhuer
Blocks are not the same. 4.5L and 4.7L have smaller average outside diameter than 5L and 5.4L. Still, it should be possible to install 100mm pistons into old style blocks. Its just like making 104mm stroker from 5L or 5.4L. Some blocks do not have enough material in them while others have, barely.
Well it sounds like you have real world experience with this. Everything I have read says that they are the same.
Old Apr 10, 2007 | 08:07 PM
Vilhuer's Avatar
Vilhuer
I have seen few but not so many to make absolute claims that all 4.7L are smaller than all 5L.
Old Apr 11, 2007 | 01:44 AM
mark kibort's Avatar
mark kibort
scots is a 5 liter out of a 4.7 euro. there is near 5-6mm of cylinder wall left
Old Apr 11, 2007 | 02:51 AM
Vilhuer's Avatar
Vilhuer
If it were typical 5L block there would be 7-8mm wall at 100mm bore size.
Old Apr 11, 2007 | 02:54 AM
mark kibort
then, after a 1.5mm bore at the edge, a normal 5 liter ends up at near 6mm for the 6.5 liter stroker. Plus, if you notice, the headgasket is about 1mm wider than the bore. doesnt seal against much meat does it?
mk
Old Apr 11, 2007 | 03:05 AM
Vilhuer's Avatar
Vilhuer
Not too much but much more than what 4.7L would have left.
