wet spark plug
Subscribe
Mar 13, 2007 | 01:11 AM
Hi Guy's
I have a 1987 928S4 which I suspect has a leaking injector seal.
The previous owner (recently) had the whole intake system reconditioned with new porsche parts however I still experience problems every now and then with what feels like misfiring and erratic idle for about 1 to 5 minutes after startup. When cold or hot.
When I last changed the spark plugs I noticed that one (1) of them was wet with fuel ! I suspect this is my problem . Could this be a leaking injector seal or is it more of a spark thing.
The car has new leads and ignition parts as well as reconditioned injectors and new seals etc.
Any suggestions would be appreciated
Reply 0
Mar 13, 2007 | 01:29 AM
It's kinda funny but I found one on my 944 assuming that I had a leaking injector on the number 4. On the next plug change, none of them were wet. I think what happened was upon shut off, there was still a little fuel left over in the cylinder that didn't combust the fuel injected into the cylinder.
a faulty idle stabilizer valve can also cause erratic idle along with a mass air flow sensor.
Reply 0
Mar 13, 2007 | 01:39 AM
Its just wierd that only one plug was very wet .
My car has a brand new mass air flow sensor.
It doesn't happen all the time ...about 60% of the time. Once the engine smooths out its fine until you turn the engine off (even for just 2 seconds).
Reply 0
Mar 13, 2007 | 02:20 AM
Spark plug wire?
Reply 0
Mar 13, 2007 | 02:24 AM
good point! Is the wire touching anything that could be grounding it out?
Reply 0
Mar 13, 2007 | 08:53 AM
Were the injectors cleaned and flow/leak tested when PO rewuorked the inlet system ?
Reply 0
Mar 13, 2007 | 10:18 AM
I'm experiencing the same symptons. Everything is new: ignition wires, spark plugs,rotors, caps, temp sensors, r&r intake, vacuum lines, oil breather hoses, injectors cleaned.
It idles okay but has a bad stumble/misse. Upon start up it runs well for approx.30 seconds then it goes into stumble/miss mode until oprerating temp are reached. When hot you can still feel a miss but hardly noticable.
HELP! Not sure what to do next if anything.
Reply 0
Mar 13, 2007 | 09:50 PM
My main question I guess is :
Does anyone think that a leaking injector seal could result in a wet spark plug ?
Reply 0
Mar 19, 2007 | 07:47 PM
Bump !
Reply 0
Mar 19, 2007 | 08:44 PM
I would be concerned about a potential engine fire.
Reply 0
Mar 19, 2007 | 08:49 PM
I would think a leaking seal would carbon the plug from extra fuel, instead of wetting the plug. Sounds more like a plug firing problem on that cylinder.
Reply 0
Subscribe
