Help with a bad clutch/torque tube Rattle Problem 88 5 Speed
#31
Under the Lift
Matt:
Order the bushing. You know you will need it at some point, if not now. Then come on over and we will install the bushing. If that doesn't work, order a rear flexplate.
#32
Unfortunately there is no flexplate, as killav (and even Rog!!!
) mentioned; the TT attaches directly to the input shaft on the trans. Did you check both pinch bolts?
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
#33
Under the Lift
Dave:
OK, we'll skip the flexplate then, but I think if we could install one in the rear, the rattle would go away for sure.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
We didn't check the torque on the pinch bolts, but I did look at them closely and there is no evidence that they are loose. We'll snug them up anyway.
#34
Ball Cup Bushing has been ordered from 928 International
While driving the car today I wanted to note that this noise is not really audible when the car is cold or even driven a short distance. It must be brought up to operating temp and driven.
A few weeks ago we were going to look and it was rattling away, we took a look at another car first and when my car had cooled off a bit the noise was not loud enough to take a look. It also seems to be loudest when you let off the gas after revving it up a bit, as the rpm’s drop to idle you get the rattle. Never hear it while driving just in neutral with the clutch disengaged.
#35
Boy Matt, the symptons you describe sound just like the old hardened exhaust shields on american cars. I don't think we have anything like that on the S4 do we?
#37
Hey Charley,
Everything transmits right down the torque tube, then add that it only really bad when it’s hot. Will get a handle on it here at some point
I’m leaning towards clutch as well.
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
#38
Under the Lift
Yeah, I forgot about that - only audible when the car is warmed up completely.
Nicole has a rattle that goes away as soon as the car warms up.
