I broke it!! Now what? (Trans cooler)
Try the usual lubes...........if they dont work try heat; caution with open flame on lube.
Get the proper size wrenches and a 'helper'. Sometimes a 'tap' breaks the seal.
When you first get the wrenches on there try going the opposie direction ie tighten.
Just enough effort to break that bond then spin them off loose direction............they are RH thread?
Captain Obvious
Super User
Super User
Originally Posted by fraggle
Mine were monster tight but if I remember correctly there are no RH thread. I just used two very large wrenches.
My cooler lines were on really tight too. They are tough to get off the first time.
When you're working on something that needs counterholding like that, try lining up the two wrenches so you just squeeze like pliers to loosen -- the pic below shows this method on a tie rod end, but you get the idea. I can generate more torque this way than by holding a wrench in each hand - YMMV.
Heinrich, what do you want 4 it? I have a line on one with the ac condenser attached, but if I can get yours faster I might take yours. I tried the "squeeze it like pliers idea" but no luck, I will try later today when I get home, hopefully the liquid wrench works.
Ceedee... Those are pics from the PO in Florida. I need to post a pic of my own, I just haven't got around to it yet. Your Avitar is better anyway.
Captain Obvious
Super User
Super User
How about this: Align the two wrenches just like SharkSkin has it on the picture, then use a small vise (you can probalby buy one for a few $$$) to squeez the two wrenches together. This should generate enough force to either break the nut loose or break the wrench. Maybe even a strong C-clamp might work too.
Has anyone just removed the nipple that the nut is attached to, and take the whole hose , nut, and nipple out at once? (the one in the Rad), and then separated them off of the car then put the nipple back in the rad. The end result would be the same, I can do that, much easier.
