LUG NUT Q!
I bought some new wheels & tires for my '84. The wider back wheels are gonna hit my fenders! Then I find these spacers on the back hubs! What a relief!! I was told by the tire rack that these cars came with these spacers from the factory. I know the guy I bought the car from knew zero about cars, so he definately did not do this. The wheel studs are a mile long!! The stock lugs bottom out before tightening the wheel! Lucky me! My question is, I have seen these "Tall" lug nuts carried by Pelican Parts. Will these tall lug nuts be long enough for these studs? I bought some basic open ended steel ones for now. The tall ones are $8 a pop!!
Grazie!
Rob
Grazie!
Rob
I run the open end lug nuts, you could cut the studs or use shorter studs but then you can't put the 21mm spacer back on with the stock wheels if need be.
Captain Obvious
Super User
Super User
I would do what you did, use open end nuts and leave the studs as is.
I will have to play & see which direction I will go! Thanks!!
What about those tall nuts, will they fit??
Rob
I do not know how much longer these lug nuts are. They look to be quite a bit longer in the picture on the website, possibly the 21mm you speak of. I submitted a question about this to their tech department. Hopefully they will know.
Rob
Rob
Originally Posted by Edgy01
Are you clearing the calipers? Can you fit your spare on if you need to? (without the spacer?)
I put a back wheel on after removing the spacer & the wheel seemed to seat fine, other than the too small lug nut!
Use open ended nuts and leave the studs as-is until you find the right spacers to clear the calipers and axle bits. open nuts can be found at any vw shop, for alot less than $8 per, and they will probably be sold in packs of 4...
I always thought that one of the bolts is supposed to have a red dot, helping you to position the inflation valve when mounting the wheel. Now why did you have all 5 painted red in picture shown...?
Theo
http://jenniskens.livedsl.nl
http://928gts.no-ip.info
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
Theo
Theo
I now have 1 red painted stud on the SE, does this mean I have to put all 4 inflation valves on the right rear wheel? LOL
I never did figure out how Porsche decided which stud would be painted red.
Supercharged
Theo
Theo
This topic was discussed at length about a year or so ago. Have fun reading...
https://rennlist.com/forums/928-forum/262702-show-me-your-stud.html
Yeah, basically the red dot annotates where to put the big, retarded, and ineffective wheel locks, i have all five of the studs painted so i can put 5 locks on each wheel.
Grazie!
Rob
Grazie!
Rob
