Mobil 1 synthetic 15w-50 $4.74 qt
FYI...I picked up two 5 qt jugs at walmart yesterday...$23.62 a piece. 10qts for $47.24... 4.74 a qt is a pretty good deal.
Basic Sponsor
Great deal its nearly $7 a quart here in DFW.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Owns the Streets
Needs Camber
Needs Camber
Only seen 0-30W M1 at Wallymart.
They did have the price sticker for 15-50W M1 but no stock late last year at one WMart I sampled.
M1 used to be $4-5/qt. couple years back.
$50-$60 a year for oil isn't that bad tho.
Ernest (NYC) Did see Shell Delvac at local AutoParts store.
Tony - that's a pretty good daily price, although I've been getting it for $4.09/qt @ Target... actually, they have clearance periodically and last week I picked up all 12qts on the shelf for $2.98/qt !!
Great, you save $4 over Amzoil, and if you track your car and get temps in the 260f range, look what has happened to many 928'ers. What does an engine rebuild cost??
Amzoil, cheap insurance!(or Redline, or even Kendal racing oil changed more often)
I think if you are not racing or DEing, mobil 1 is probably fine on a 928.
No one has shown me why ive seen lower hot oil pressures with mobil 1 vs other high end oils.
at buttonwillow, the hot oil pressure got so low using mobil 1, that the oil pressure light was coming on!
MK
MK
Nicole- +1 !! on Walmart. place is a cesspool...
Mark all the oils you mentioned are good- don't know why you had issued with M1. Been in my car for 10 years,track included.
steve
steve
Originally Posted by Chris
Interesting, Wallmart pulled the 15/50 from its shelves here last year, wonder if they are going to put it back .. .will have to check.
Chris
Chris
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
most all of the 928 failures has had Mobil 1 in common.
Doug gave us good information regarding the stability and viscosity of Mobil 1 and reviewed my 3 to 4 race weekend old Amzoil racing oil after it came back from analysis. However, never was the oil viscosity at racing temps discussed.
What i have found is that there was a big difference at 250F temps in the oil pressure my old 928 had. in fact, even Constantine's 928 was seeing lower than 3-4 bar pressure in the last race.
Ive never seen less than 5 bar with amzoil or redline racing 20-50.
Ive also pulled apart my old 4.7 after 170,000miles, 40k of mostly racing and the rod bearings looked excelent.
of all the snake oil and mystery things to buy to help protect your engine, i think engine oil is the easiest to hedge your bets with, and we do have some imperical tests that have shown that some oils just fall down as far as pressure, at racing temps.
MK
MK
steve
steve
I thought porsche recommends 20-50 for our 928s (at certain operating temps)
MK
MK
Originally Posted by ErnestSw
FWIW it's the 5W40 that Doug Hillary recommends.
