Devek Aluminium Rad LEAK!!!
Originally Posted by Randy V
IIRC - the 'Achilles Heel' of the DEVEK rad is that the end tanks are glued on with an epoxy compound.
Owns the Streets
Needs Camber
Needs Camber
Mine went just after 2 years. Guess it's the uneven roads around NYC.
Was the welded end cap one. Looks real nice and shiny in the box.
Shoulda just left it in the box.
Went with used Behr from 928 Intl. Upstanding vendors.
Got 2 reseal kits (for both sides) and rad shop resealed the used Behr.
Now that I know better (from Rennlist wisdom), I should have swapped in 2 fresh end tanks as well.
Live and learn.
Anyone with the C&R 928 Intl rad report on how's it holding out?
Ernest (NYC) aka Keptun Kewlant.
Live and learn.
I've got the 928 Intl unit.
Cool as a cucumber. No issues. Led a tour last year over the mountains, I think we were in the high 90's, maybe even triple digit heat. Uphill, full throttle where traffic would allow. Two of the guys red lighted, I think a couple others hit the red zone. My car was just below the top white line. It's a good unit. I got in prep for the Stroker build, I don't think I'll be disappointed.
Coolmax...
Originally Posted by Ed Hughes
Roger, I'm sure a Radiator shop would be able to repair these....
G&L here in town will, I can confirm they pulled out a miracle on my current YZF's aluminum rad. They make a lot of custom rads and aftercoolers for high power imports too... for around 250 bucks...
Wonder what they'd make a 928 radiator for? I'm lucky in that I got a new Behr with the car.
G & L RADIATOR CO 423-622-0641
4116 Ringgold Rd
Chattanooga, TN 37412
Oh, and check out the Website: G&L
Michael
I think this largely explains why some people have good luck with these and some people do not.
THOSE of you with intact Ron Davis Racing/Devek radiators...get yourself out into the garage tonight or tomorrow or at your first availability and unless you have done it within the past year....CHANGE YOUR COOLANT! And make sure you keep the concentration of coolant at least 50%. Fresh anti-corrosion additives are necessary to keep this part alive.
N
Originally Posted by cfc928gt
From what I could find the DEVEK radiators were originally epoxied until sometime around 2000/2001. Epoxy will eventually fail. DEVEK did offer me a replacement for 15% off even though it was the PO who put it on. I went with a used Behr that I got from Gary Knox two years ago and it works great.
Harvey
The BEHR in my 78’ Shark just sprung a leak today too. It’s a small pin hole about midway up between the two cooler lines on the driver’s side of the side cap that faces the engine. It doesn’t seem to be leaking along any seal – but the actual housing of the cap itself.
Basic Sponsor
Bret,
You can replace the end cap once.
Get a cap and seal from 928 Int and find a local shop that can change out the caps.
About $120 for the cap and seal and about $100 to fit it.
Roger
Roger
Rog-
Why are the caps replaceable only once? I bought two end caps and seals and took it to radiator shop 928intl referred - they placed new tabs on it. $125 for labor BTW in a shop located in Santa Ana I recall.
Just curious.
Just curious.
New tabs
I dont want to beat this to death but what I was mentioning is they placed new tabs as part of the replacement of end caps and seals.
maybe I'm wrong, maybe not, just want everyone to know the options available. I can call the rad shop tomorrow to confirm.
928 Collector
