Installing 951 pistons into S4 engine.
edited title for clarity - RV
This is somekind of cross-road to me as I'm really tempted to buy a '87 S4 that is listed near me and I always fancied the idea of a turbocharged 928 32v.
I bought those pistons for my 2.5 16v turbo, but it's not too often when you get a hold of 8 of them.
Also, I have brand new KKK K31 turbo that suits fine on the 5.0liter engine, has twin-inlet turbine and nicely designed compressor wheel.
As I install VEMS engine managements and done this on 928 also, that won't be a problem also.
I have the skills, facilities and even a bit of cash to throw at it, just my other projects are not done yet. Then again, I've got almost all that I need for proper turbo conversion.....
I'd appreciate if you guys pint me in the right direction or just a wake-up call
The 951 pistons are a bit short. You will either need to buy some custom rods, or figure out how to offset the pin on the current 928 rods to move the piston UP.
There is third option, take out 2mm from the block deck. This will create whole other set of problems, especially in S4, but they are solvable.
I was reminded Via PM that there is a working motor doing this exact thing with stock everything with the 951 pistons, which makes that one in Green bay, and one in LA. Both have a very very low 7.3 or 7.5 compression ratio.
...in the meaning that it results in a way low CR or upsets squish area by too much?
Custom rods are quite a hack to the wallet but I could get my machinist to make the offset bushings as he purchased new coordinating bench for this kind of work.
EDIT: Ok, got the CR info, thanks.
Milling down the block is not a bad idea since there are adjustable cam pulleys and it can be dialed out. Correct me if I'm wrong.
Thank you Tony! Excellent gallery!
Any more info about the engine? I mean, I've always concerned about the longetivity of a Nikasil/Alusil cylinder wall coatings when they are not freshly treated...
And here's some pics of the K31 turbo I have. It flows a nice 76lbs/min and has perfectly sized turbine for 5.0liter engine.
![](http://img90.imageshack.us/img90/5024/picture010ti8.jpg)
![](http://img90.imageshack.us/img90/1646/picture008mf2.jpg)
![](http://img90.imageshack.us/img90/1543/picture009yd3.jpg)
Sorry for the not very accurately asked question.
I have pretty good experience with 944/951 blocks and they tend not to wear for some time and then a sudden disaster. Cause: coating is just worn out.
If I understand correctly, 951 and 928 blocks have the same treating?
It is not a coating/treatment, it is what the blocks are cast out of , just like a cast iron block would be made. The pistons of the 944/951/928 run directly on the bores, the alusil bores.
"and they tend not to wear for some time and then a sudden disaster. Cause:coating is worn out" , in what way ? .
Down load the Reconditioning of Aluminium Engine Blocks
That should help in explaining things far better than I ever could
