Best Sealant For WP and Oilpan Gasket is?
I have seen many different products as I have searched threads.
What can I pick up at an autoparts store that will work the best for the waterpump gasket and what works best on the cork oilpan gasket?
TIA
Bernie
TIA
Bernie
I've always put the pumps in dry: for pan gaskets, I used the thin cork/neoprene composite gasket - also installed dry.
Still anxiously awaiting my first leak ..... yawn ...
Originally Posted by Panzer9
YAMABOND ( Manufactured By Yamaha)- Very highly recommended
I have a tube of what is called MotoSeal 1 by Permatex which I believe is Permatex's version of Yamabond if I am not mistaken?
Cheers
Bernie
Sharkaholic
Originally Posted by Bernie
Is this the gray sealer?
Cheers
Bernie
Cheers
Bernie
Under the Lift
Under the Lift
Bern: Any of the non-hardening Yamabond equivalents work fine for the WP. I've used Yamabond, Hondabond, Threebond and Hylomar at various times. Hylomar is the best looking - beautiful, deep translucent blue.
I use permatex copper spray-a-gasket. All of the RTV sealants are kind of messy and as some have said, require the user to apply them evenly, use the correct amount, etc. I just spray the stuff on the gasket and let it set up for a few minutes and install. It has decent adhesive properties which is nice as it holds the gasket in place while you install the part. Removal can be a pain but that's why they make gasket remover as well.
Under the Lift
Yamabond cleans up with brake cleaner.
Gasket remover: a tip from experience - I tried Wurth gasket remover one time and it nearly burned my skin off while working no better than Permatex. You could probably take a bath in Permatex's gasket remover.
