Dropped oil pan found crank scraping on block!
Under the Lift
I saw the same thing when I did my oil pan gasket. Everybody has already chimed in with the answer. The machining can fool you. If you didn't have a chance to observe the condition of the thrust bearing, do the end play measurement to reassure yourself. Pictures of real TBF show more damage.
http://members.rennlist.com/v1uhoh/9...earticleTH.pdf
