928 Forum 1978-1995
Sponsored by: 928 Specialists
M28/47 questions
Old Feb 2, 2007 | 07:26 PM
davek9's Avatar
davek9
Does that mean that MY's 78 to 86 fire in a different pattern i.e., one at a time or other than you guys described above?
Thanks Jim,
DaveK9
Old Feb 2, 2007 | 07:35 PM
Jim bailey - 928 International's Avatar
All the electric injector cars fire all the injectors at once...batch fire The early CIS cars which is Continuous Injection System the injectors spray ALL THE TIME just varing amounts.
Old Feb 2, 2007 | 08:10 PM
davek9's Avatar
davek9
Go it, and thanks again Jim!
Never did catch what MY EpsonT was converting.
EpsonT?
DaveK9
Old Feb 2, 2007 | 08:26 PM
atb's Avatar
atb
JB wrote:
I seem to recall it being twice per revolution but not sure why I think that ??
Isn't it twice per revolution to a certain rpm level, then once per with an extended duty cycle?
Old Feb 2, 2007 | 08:56 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
Originally Posted by Jim bailey - 928 International
I seem to recall it being twice per revolution but not sure why I think that ?? I never got too excited about it since it is not going to change.
Louie mentioned in a Sharktuner review that it switches over at some higher RPM.
Old Feb 2, 2007 | 09:27 PM
FlyingDog's Avatar
FlyingDog
Originally Posted by atb
I think it is once per revolution of the crank or twice per complete combustion cycle. Above a certain point (5300rpm at WOT?) it changes to once per combustion cycle.
Isn't it funny that we're all speculating instead of just picking up a WSM or using the Rennlist search function?
Old Feb 2, 2007 | 10:27 PM
AO's Avatar
AO
Supercharged
I think we're all wainitng for J. Speake to chime in. Lazy bastard!
Old Feb 2, 2007 | 10:28 PM
docmirror's Avatar
docmirror
Shameful Thread Killer
Jim, this is nearly correct. The CIS system has fuel pressure to the injectors all the time. The pressure determines the volume of fuel that is drawn in during the intake valve openning and piston withdrawal. The piston moving down creates an area of 'negative pressure' for lack of a better term, overcoming the spring in the check valve of the CIS style injectors, and drawing fuel into the intake. That's why the CIS style injectors have to be close to the intake valve, there is no CIS throttle body injection, just multiport.
The CIS injectors are shut off during intake valve closed time. It is a remarkably efficient mechanical system, all based on pressure from the metering plate to the fuel pressure regulator.
Doc
Old Feb 3, 2007 | 12:30 AM
danglerb's Avatar
danglerb
I don't follow this, isn't the whole intake at a lower pressure during idle than any other speed?
Or does the fuel pressure track the manifold pressure to compensate?
Sounds kind of touchy.
Old Feb 3, 2007 | 12:35 AM
Bill Ball's Avatar
Bill Ball
Under the Lift
Yes. The fuel pressure regulator has a vacuum line from the throttle body.
Old Feb 3, 2007 | 12:56 AM
Tony's Avatar
Tony
Hes a sleep at this hour...or crawlimg home from the pub.
IRRC its appx 51-5200rpm the switch occurs...not sure..but it does occur.
Old Feb 3, 2007 | 01:16 AM
Bill Ball's Avatar
Bill Ball
Under the Lift
I haven't seen it in the WSM. I tried searching Rennlist. I know it was in a discussion of the Sharktuner by Louie, but I've struck out so far.
Old Feb 3, 2007 | 08:42 AM
EspenT's Avatar
EspenT
Ok.. I've got the picture now. I was also asking about the EGT sensors.. Would they work together with a EGT gauge.
dvaok9, I has a twin turbo converted m28/47 and was rebuilding the engine harnes so i could use it together with my DTA p8pro ECU.
Old Feb 3, 2007 | 12:17 PM
davek9's Avatar
davek9
EpsenT I got all that from your first post.
My question to you was what model year of 928 are you converting to a drifter?
Old Feb 3, 2007 | 01:14 PM
EspenT's Avatar
EspenT
Ahh.. Sorry davek9. It's a 79.
