Pics of taillight lens and interior LED update
That looks great Ed, really good.
Under the Lift
Originally Posted by sharkmeister85
Nice upgrades, Ed! How does the brightness of the 42mm in the overhead map light compare to the stock bulb?
Glenn
Glenn
Originally Posted by Bill Ball
You need the 2 HP (high power?) LED 42mm festoon, rather than the 9 LED 44mm festoon for the overhead.
I have installed a few of these LED dimmers with the Jager kit. I've had on in my own car for several years now but with 3 light bars with 6 LEDS on each. It works fine. Adjusts from off to full bright. No flickering.
LED DIMMER
LED DIMMER
Craic Head
Ed,
That looks awesome, very clean. Are the LED bulbs a direct replacement or do you have to rewire?
I really like the rear lights, they came out nice. Very eye catching. Nice work.
Mike: The bulbs are a direct replacement, with the exception of having to bend the contacts in the receptables enough to fit in the 9 festoon lamps with are 2mm longer than stock. No big deal, it would be hard to goof up this process.
The 2HD festoon bulb I put in the maplight was the only one that was sensitive to polarity, unless I lucked out with all 5 other the 9 festoon bulbs and got them in properly. All told, about $35 for the 6-I didn't do the glove box light, as it isn't open much, and if I goof up and don't close the rear boot, no danger of that light staying on all night, as courtesy lights would.
