cis pressure gauge
where can i get a pressure gauge to inspect cis pressures, like the fancy one seen in manual? it looks expensive, is there somthing like it that will suite. also can the fuel pump pressure be measured with a normal gauge in a normal fasion? "normal fasion" meaning pressure at end of fuel line and not a passive test? the specs supplied are in delivery volume what about pressure? im sure you can get adaquite volume with inadicuate pressure. i understand the system enough to know it needs more than correct fuel pressure to work properly but it seems the by the book test procedures asume no fault in system pressure regulator. i know someone out there in rennlist land knows enough about this to make my head spin bring it on
I'd go with the harbor freight option or get one from tool warehouse dot com. Be advised that there are several different iterations, make sure you get one with two hoses and with a switching mechanism to read system and control pressures. And adapters.
