Do All Superchargers Have The Whine?
#31
Captain Obvious
Super User
Super User
Originally Posted by IcemanG17
Bills is very quiet....but its hard to hear anything other than the melting tires!!
As far as I know there was only one tire spinning on Bills car.
#33
Depends on the unit. As stated though, nothing sounds as good as a turbo...sounds like the cars is saying sweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeet!
#35
Davek9
The quote for the C38 units that i got was 3312 USD incl danish VAT (VAT=25%) but in the US the quote is 2295 USD.
Dont think it's a mouse trap they are using rotrex units on the koenigsegg + ferrari's + bmw's etc
Bernhard
928 dot dk
'87 S4, x-over,rmb,cats
Bernhard
928 dot dk
#36
There is one C38-81 Rotrex setup for GT currently under work that I know of. Original plan was to put it where airpump is but there isn't enough space. Current idea is to put it on other side where alternator is and put small alternator in place of airpump. Late model VW diesels have small alternators which produce enough to work as replacement for stock version. If such part will actually fit between AC and cylinder head is found out during next week or so.
Rotrex plumbing will be pain but it looks doable. Current thinking of crank drive is that AC will use stock V belt wheel as its furthers back anyway and thus it can stay in stock position. Power steering pump will stay in same front/back position as stock too but will be mounted to same plate to where Rotrex is also mounted. SC uses 8 rib belt at frontmost position on crank. In between these there in will be 6 rib belt for alternator.
Cheapest place which sell these was in UK. Cost was around 1600-1700 euros. Manufacturer in Denmark asked 1800e for same package.
Rotrex has taken SC rpm to all new level I think.
http://www.rotrex.com/pdfs/Rotrex_Te...Range_V1.7.pdf
#39
Dean of Rennlist, "I'm Listening"
Originally Posted by heinrich
For a man who will soon have nothing to supercharge ......
Plus, the eBay bidding is stuck on a paltry $22K. No, wait.
#40
Looks like it would be suited to go into the same place the V sits with Tim's Kit. The bracket would need a different dimension.
#41
Tim = Tim Murphy from murf928 com ?
Seems like the site is still "under construction" has anyone got pics/ link of the murf install ?
Bernhard
928 dot dk
Bernhard
928 dot dk
#43
