Tensioner band how to tighten?
Basic Sponsor
Mark,
If you are talking about the clamp that goes around the rubber seal on the tensioner use a pair of tile nippers if you have any.
There was a thread about this subject recently.
Roger
Roger
Under the Lift
Crimp it by squeezing it from the side carefully with wire cutters, if you do not have an end cutter plier (or a tile nipper like Roger mentioned) or a CV band crimper.
Under the Lift
I hope he's not talking about the timing belt tension! For some reason that isn't too clear right anymore, I thought (and so did Roger) he was asking about the tensioner rubber boot clamp. Eeek!
