Specific timing belt related questions
T-Belt Trivia anyone
Q.1. When I did my timing belt (on 5-spd), I set the e-brake and left the car in neutral. Does it make any difference if it was in neutral or in gear (I used the flywheel lock tool)? With an auto, do you put it in neutral or in park?
Q.2. There is one bolt in the t-belt tensioner that must go into some kind of oil jacket or pocket or reservoir; some oil runs out when it is removed. What is it actually? What is behind there?
Q. 3. How many bolts are used to hold the pre-87 undertray on?
Q. 4. Does the Wiring Harness on an 85/86 normally run in front of the t-belt covers above the viscous fan mounting bracket or underneath it? Mine was running behind the t-belt covers.
Q. 5. What is this wire called (function)?
Q. 6. Is the hole in the water pump boss, where the small roller is pressed onto (85/86), purposely sealed on the rebuilt pumps or is it new paint that has covered the hole? Does it matter?
Thanks everyone!
![](http://forums.rennlist.com/upload/tenbolt.jpg)
![](http://forums.rennlist.com/upload/elecwire.jpg)
Thanks everyone!
That's alls I know after one TB job on an 86.5, so other better experts may chime in.
Matt
HTML Code:
Marton
Chronic Tool Dropper
That red wire goes to the terminal at the LF fender, inder the ABS valve on my S4. I think it powers the ABS pump, but that's a guess.
John,
RE: Q.2. There is one bolt in the t-belt tensioner that must go into some kind of oil jacket or pocket or reservoir; some oil runs out when it is removed. What is it actually? What is behind there?
Yes that bolt hole does seal a passage...in the WSM it advises you to coat the threads with a sealant when re-installing it. If I remember correctly there is a coolant passage behind it.
Glenn
Glenn
Craic Head
Glenn,
I think you're referring to the bolt that holds the tensioner arm on. This one goes into the cooling passage and if you try to remove your tensioner arm to, say, switch the bolt on the lower roller around so it doesn't rub against the dampener for example, without draining the system again you'll have it pissing on your feet until you plug it with another bolt.
It can be done without losing too much coolant, but it's not recommended.
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Mike,
I looked it up in the WSM (section 15-10 & 11) and it shows the bolt for this hole (14a) to be installed with Loctite 574 which Loctite lists as a "form-in-place gasket".
Am I looking at the right part here? Anyone else remember this when they did their TB/WP?
Glenn
Glenn
Originally Posted by gbarron
Mike,
Thanks for the replies everyone
I guess on question #2, when I took the tensioner bolt out, some tensioner oil must have back-flowed into the hole (?), then maybe a dribble of mixed coolant and oil ran out. I saw oil running out, but if it is a coolant jacket or passage, then a little bit of coolant may have ran out too and I just didn't notice it (the block was drained).
On question #4, I guess it is normal for the wiring harness to pass behind the timing belt cover on the 86- instead of coming out in front of it like the 87+.
On question #6, the tensioner arm shaft bolt hole was sealed on the back side, in the coolant passage, and it looked like paint had probably gotten in there and sealed it off. I'm sure it's no big deal.....probably better that way.
Thanks again!
Thanks again!
