Self-healing Flat
Self-healing Flat
Has anyone ever had a self-healing flat? I'm puzzled (of course I'm going to have it pulled and inspected) by a tyre that was flat overnight but since I inflated it after that, it;s been fine.
I had one where if you parked it at the right rotation the weight of the car held the hole in the tread shut.
Have you been driving it since you inflated it?
Do you have kids in the neighborhood who might have let the air out?
When was the last time you checked air in the tire before it went flat? Sometimes the schrader valve doesn't seal all the way when you inflate or check pressure due to debris or age, then the next time you inflate the tire it seals fine. WYAIT replace the valve core, and look closely at the old one. You may see something amiss with the seal(or not).
Dave, good thoughts, mine exactly ... but the tyres were mounted on these rims about 2 months ago. Should be ok. The car did sit a weekend at an airport in the covered parking ... I hope I didn't drive all the way from Portland with a flat, but I reckon I would have felt it....
Heinrich,
How about the little twisty thing inside the shrader valve (maybe that's the valve itstelf or the 'valve core' Dave was talking about). The one that you unscrew to quickly inflate/deflate. Maybe it's not tightened at all, but it just wiggled loose and then got seated.
One time after service on our van I noticed one was so loose it almost popped out from the pressure of the air. The guy that put it in just didn't tighten that one beyond finger tight. Could have taken a few weeks to work it's way loose enough to leak.
