Heated seats not working
Originally Posted by Pfunde
Yep, disconnet the wire under the seat and messure resistance - if none - element is broken
I've got heated seats with the rheostat built in the switch and mine don't work either. Anyone had any luck trouble shooting this? Better yet, anyone have the PC board from a functioning unit that I could borrow to trouble shoot my own?
Unplug the heating elements themselves--they're the two-prong jobbies that (I think) have what looks like a mercedes symbol on the plug. The plugs are generally secured to a plastic plate that hooks onto the seat bottom springs. The wires can be traced and run into the seat cushion/seat back. You can check for continuity using a multi tester.
Fleet of Foot
Hey Bill,
Thurston Pritchard, one of the local auto electric guru's had one of my seats in his lab for awhile. I bought a replacement switch to see if that would help with the trouble shooting, but it didn't make a difference, it's somewhere in the PC board from what little I understand. He said that if he had a functioning unit to probe he could figure out what the problem is with mine. Apparently its a common problem with the adjustable units. He did say he could convert it to the earlier on/off style without a problem (the elements work fine), but I'd really like to have the adjustability. Right now, mine don't work at all. I think he did get them to heat up by holding the switch in like what you mentioned, and putting in a new switch didn't help.
Fleet of Foot
Adam, If Thurston finds the problem, could you post the result or contact me? I have a feeling it is a solid-state relay in the controller unit that is not latching electronically. Would be nice to know if my suspicions are correct.
