Front lower control arm bushing
Under the Lift
Originally Posted by Andrew Olson
The key is dimensions. Does anyone have dimensions for new-unused busing? Also, I just remembered that there's a 928 owner here in MI that works at a rapid-prototype shop. We might be able to get some insight from him on materials, mold costs, etc. I'll be seeing him on Thursday.
Supercharged
Originally Posted by Bill Swift
Just updating. I just ordered a used one from 928 Int'l. It it their belief that the bushings are molded to the control arm and at this point in time there are no replacement bushings available.
Does anyone have a picture of the front control arm without the bushings?
Archive Gatekeeper
"The front one is supposed to be torqued after the car is on the ground"
928 Barrister
I also torqued mine before the car was lowered to the ground after replacing my shocks. Maybe that explains my wandering steering. I will also be interested in a source for new bushings, and the prices Andrew mentioned are not objectionable at all.
I bought a set of the lower control arm bushings from this Australian guy a few years ago when he still had them. I put them on a later arm after powdercoating them. I have not installed them, but we will see if this was a good idea. It not a small process. The bushing at the back is fine once you have taken the old one off, but the front one with the metal carrier over the arm's shaft was a doosey. I put them together with a bit of urethane compliant grease.
These lower bushings seem to take a real beating. It would be a good idea to get something (realistically priced, not geared to ream people since they aren't available, ahem) going for these.
Under the Lift
I never knew this. I guess I was lucky for once.
Under the Lift
I used to torque mine in the air as well. The saving grace in my case is I also torqued it incorrectly, both front and rear to just 66 ft-lbs.
Fleet of Foot
Having a little trouble understanding/visualizing why that is. The front bushing has the metal sleeve around it and would seem to be less adversely affected by how it is torqued. The rear bushing, on the other hand, has no sleeve bonded to it, but is held to the cross-member by a separate aluminum clamp. I can understand the need to torque THAT one while under load, but not the front one. In any case, I will final torque both under load.
Under the Lift
Not sure, Bill. Look at the beginning of the WSM section on the front suspension and you will see a cryptic comment about the torque for the front bushing. Marc T said they can split if not done correctly.
Received 1,565 Likes
It's the rear bolts of the lower control arm. WSM says to leave two threads showing until suspension has settled and then torque to spec. WSM 40-15.2
Under the Lift
OK, memory failure again...front versus rear. That's why I have everything printed out in folders in a file cabinet and I pull the suspension folder when I go to do the job. Even after a dozen timing belts, I still take my TB/WP folder with me too.
Just to be precise in case someone saw my first (deleted now) post - it is the rear two bolts of the lower front control arm.
