Wheels rubbing on the inside - need advice
#61
I went over this before, but a baseball bat at the neck can be as effective as a rolling machine, actually better. you need to keep the bat as vertical as possible or you will get a duckbilled look. if done right, it almost looks like a factory flare job. push the car forward and backward to create the rolling action with the baseball bat. Oh yea, WOOD only, and loose the pry bar idea!
MK
MK
Originally Posted by Andrew Olson
I can't change the laws of physics... but I can change how th car looks. One of the key reasons for putting 11" wheels with 295's aside from the hope for more traction is for looks. I cannot tell you how bad-*** a 928 looks with max rubber! I think it's one of the best improvements (looks-wise) one can make to a 928.
So here's another questions for all of you fender flarin' experts. I've heard two suggestions for getting the fender to cover the wheel.
#1. Take a length of dowel rod (~1/2" thick) and roll it throught eh arc.
#2. Use a pry-bar with a gentle touch and pull the metal out slowly across teh entire arc of the wheel.
Is there another method? Which of these two is prefered? Remember the fender lip on the GT is already rolled from the factory.
#62
Supercharged
Originally Posted by chaadster
Saturday AM I'm yours (in the Platonic sense). Call me (*wink*wink*)
#63
Whatever you do Andrew, resist the urge to quit mid radius. (Unless of course you see that the panel is being damaged). I helped Tom M. flare his S4, and it is unbelievable how much the panel distorts while the bat is being run through it. Amazingly, it takes the stretch very well and you are left with a perfectly shaped, but flared rear panel. We couldn't believe what we were seeing and stopped halfway through the first one. Mistake. It put a vertical crease in the inner lip. Not visible from outside of the car, but if you looked up inside the fender well where the panel curls under to from the wheel opening, you could see it.
Good luck, take pics.
#64
i have 19x11s on the rear. to major rolling and some flaring with a bat to get them to fit. 295/35s are on. i did a bit of the "duckbill" look but I dont think there was any way around that in order to get these wheels to fit.
