odometer and shift indicator lights????
Rest in Peace
I need help with my odometer and shift indicator lights
We pulled the speedometer out of my 87 and replaced the gear which toast.
put everything back together and I still have no odometer. Can the gear that rides on the shaft for the speedometer be slipping?
Does any one have a write up on how to change the lights and which bulbs to use for the gear selector indicator
Also,
Did you have any spare parts
Just kidding, when I put mine back together I spun the first dial to make sure everything was catching. You might want to make sure everything is interlocking correctly, it might just be on too loose or something.
?Just kidding, when I put mine back together I spun the first dial to make sure everything was catching. You might want to make sure everything is interlocking correctly, it might just be on too loose or something.
When I did mine every thing was not engaging when I finished replacing the gear. I messed with it for 20 or 30 minutes before it began to engage continuously. I can't tell you what I did because I don't really know. Sometimes you just have to futz with things for a while before they are willing to cooperate. I know you don't want to hear that you need to take it apart again.
Rest in Peace
Originally Posted by ZEUS+
We cleaned out the little peices of the gear that was left and i did turn the small white gear on the central shaft and it moved the odometer, maybe I got something lose when I reinstalled it.
Pulling it out is not a biggie any way. The only tricky part is getting the needle off of the shaft, we used one of those tools that are for door panells that push in 2 directions when you squeeze them.
Thanks guys
Rest in Peace
Originally Posted by Rick Carter
Interesting; replaced the odo gear on my 85, all seemed well but then it quit working again, then just recently it started working again on its own.
I guess I could try to pin it with maybe a part of a paper clip and drill a hole with a pin vise and a small drill bit.
