928 Forum 1978-1995
Sponsored by: 928 Specialists
Are 928 Top End Speeds Getting Faster?
Old 12-01-2006, 09:31 PM
  #91
Brett928S2
Brett928S2's Avatar
Originally Posted by Tahoe Shark
I have no doubt that my fellow competitor George will be there, he is very dedicated to this goal and has worked diligently to improve his speed year after year. If we both make it there will be 3 928's on the 200 mph club web site.
Hi
Maybe 4 if Uk cars count
All the best Brett
PORSCHE 928 S2 AUTO V8 4.7 LTR 1986 IRIS METALLIC BLUE WITH X-PIPES ,RMB ,PROMAX CHIPS, KICKDOWN SWITCH, K&N, WIZARDS OF NOS - NITROUS KIT 150 HP JETTING - 505 BHP / 500 FT LBS TORQUE
PCGB UK 928 FORUM MODERATOR - Email managingdirector@pchealthcare.co.uk
Old 12-02-2006, 06:23 AM
  #92
stuartph
stuartph's Avatar
Guys
So if you have the BHP what gearing off the shelf will get you over 200mph
Old 12-02-2006, 08:26 AM
  #93
khalloudy
khalloudy's Avatar
I would love to add a SC to my car, but i do not want to mess a lot in the already crowded engine compartment. If someone could make a setup that retains the factory look and hide most of the components (i guess except the obvious SC)... then it would be a definitely interesting proposal... Many of my friends indicated the same thinking... plus i do not drive that fast on a regular day to start with...
Old 12-02-2006, 08:53 AM
  #94
Brett928S2
Brett928S2's Avatar
Originally Posted by stuartph
Guys
Hi
I think mine is 2.73 or 2.37 lol (not at home with the figures at moment)
Whichever it is it gives a theoretical top speed of 225 mph....and I doubt my aerodynamics will EVER allow that even if I do take mine up to 1000 hp as I intend......
All the best Brett
928S2 AUTO V8 4.7 LTR 1986 IRIS METALLIC BLUE WITH X-PIPES, RMB, PROMAX CHIPS, KICKDOWN SWITCH, K&N,WIZARDS OF NOS - NITROUS KIT 150 HP - 505 BHP / 500 FT LBS TORQUE.
PCGB - 928 - FORUM - MODERATOR.
EMAIL : managingdirector@pchealthcare.co.uk
Old 12-02-2006, 08:55 AM
  #95
Brett928S2
Brett928S2's Avatar
Hi Khalloudy
If you want it hidden ..Nitrous is the answer....you could easily hide the solonoids in the engine bay and use a small bottle which could be hidden anywhere in the car...
All the best Brett
Old 12-02-2006, 09:04 AM
  #96
khalloudy
khalloudy's Avatar
Brett,
Nitrous is an option, but i am not too keen on riding on a bomb... plus having to recharge is an issue and the added heat on the block. The SC configuration is the best considering all new high performance cars are going that route (AMG and all...) just my thoughts.
Old 12-02-2006, 09:08 AM
  #97
Brett928S2
Brett928S2's Avatar
Brett,
Hi Khalloudy
Lol...you have the common misconceptions about Nitrous...
1, Nitrous is NOT explosive
2, Nitrous is NOT flammable
It is purely an oxidiser....it also COOLS the block...not heats it..
The advantage of Nitrous for you would be....the car drives perfectly normally UNTIL you arm and hit the switch..
Nitrous is fairly easy to find....most dentists use it...so you just get their supplier to fill your bottle for you...
All the best Brett
Old 12-05-2006, 10:35 PM
  #98
MorganRock
MorganRock's Avatar
another good option for near-hidden hp gains (on an S4 the FMIC is totally hidden) is Mark Robinson's www.928turbosports.com turbo kit... mid-mount turbo = no-see-um hp gain
I've ridden in his test car too, power is smooth and comes in early... very well-sorted kit.
Old 12-05-2006, 11:20 PM
  #99
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,790 Likes on 1,358 Posts
This thread is useless without a popcorn icon......
Old 12-05-2006, 11:32 PM
  #100
H2
H2's Avatar
Do you mean that the recently popular superchargers aren't really affecting the top end performance of 928s? It doesn't make sense to me that such a modification wouldn't make a difference, since it takes HP to break through the "5th gear wall' in a meaningful way and these cars are cranking out a lot of extra HP. Or is there a gearing/upper end RPM limitation in spite of the HP increase? In other words, you are able to attain your top end speed faster...but your top end doesn't really change all that much with more HP? If so, I'm not sure that's what I've been reading. Or am I wrong?
H2
Old 12-06-2006, 02:54 AM
  #101
SharkSkin
SharkSkin's Avatar
Probably what's affecting top speeds more are roads, cops and *****. You need a good road, no cops, and serious *****.
Seriously, how many of the folks with superchargers or turbos have really tapped their cars out to "see what she'll do"? Not many, even fewer will admit it in writing. Sanctioned events are another story, but it takes a lot of work to be able to pass tech & run a sanctioned event near the top speed of an SC'ed 928 with 2.2 gears.
Old 12-07-2006, 01:49 PM
  #102
Gnarly 928
Gnarly 928's Avatar
George Sunnen seems to be the only one actually "Walking the Walk" with a supercharged highspeed effort. Everyone else just says.."Oh, my car will do XXX.XXmph..., or it SHOULD, as soon as I______"
As I am sure all the 'actual' open road participants will confirm, really going really fast is more difficult than just saying you can go really fast. It takes some very methodical preparations, a fairly serious and sustained commitment of your time, probably a few incrementally faster attempts to reach high speeds, and some courage. Courage to actually put down your 'go-foot' and leave it down and courage to commit to the effort and take the chance that you might fail or wimp out or some such.
On the other hand, it's an enjoyable effort to make, and you learn a bunch by doing something pretty "far-out" with others who are willing to push it a bit, also. Heck, just spending a few days in Battle Mountain, or driving in the Ely 'Competator's Parade" down mainstreet Ely, Nv...that alone is worth putting down the TV remote..
Anything over about 170mph, I think it isn't just one thing limiting your speed..not gearing, not hp, not aeros..but more a combo of all of those. At those speeds, everything has to be as right as possible..any one aspect slightly wrong, and you won't be getting much above 160-170...HP and Aero will be the ultimate limitors. You can add one or dimish the other and increase your potential top end, but running up at those speeds is VERY difficult to acheive. Again, ask anyone who has actually tried it..It is a real challenge.
Don Hanson
Old 12-12-2006, 05:12 AM
  #103
Tom Cloutier
Tom Cloutier's Avatar
How is it that 20mph is the only "safe" speed? The faster you travel, the greater your chances are of encountering some other obstacle that could harm you. Also with increasing speed you are exposed to more situations which might threaten your safety. Even standing still is not completely safe. And an asteroid may strike even the most secure concrete bunker buried under a mountain!
If any of our lawmakers get wind of that report we'll be seeing 20mph speed limits on US freeways! At least the insurance companies will be happy and rich!
Live fast. Drive fast. Die young. Make room for the next guy!
Tom Cloutier
Old 12-12-2006, 05:24 AM
  #104
Tom Cloutier
"And unlike the supercharged cars, which hit their limit because too much boost blows the head gaskets, nitrous will not have that problem."
I don't think it's the boost that blows head gaskets, but rather the additional pressure that results from burning a larger volume of air and gas. That's what blowers do: pack more air into a cylinder so that more gas can be ignited and more energy produced. In fact, boost pressures are very low compared to combustion pressures in a closed cylinder.
Nitrous is another means of getting more air into an engine so that additional gas can be burned. Pour in enough nitrous and the head gaskets and lots of expensive parts will assume new and unusual forms just as with blowers!
How do you know when it's enough?
Tom Cloutier
Old 12-12-2006, 05:47 AM
  #105
Ron_H
928 Barrister
Ron_H's Avatar
OK, I've tried. I really have. But I must butt in. Try to remember this axiom:
As the speed increases, the accident and death rate decreases. Proven fact, within reasonable boundaries, of course. Trying to imitate Craig Breedlove on a congested city surface street might test the above statement. But the speeds at which traffic is moving in this country presently, relative to that traveled a couple of decades ago, is steadily rising and the accident and death rates are dropping. Certainly vehicle design and highway construction have contributed, but that is precisely why drivers feel safer at higher speeds, and, believe it or not, the safest drivers are those that travel at the highest speeds. They suffer the lowest accident and fatality rates of all. So much for the 20 mph theory, (though I understand the spirit in which it was posted). The key is traffic FLOW, NOT speed restriction. In accordance with that objective, trying to keep everyone's relative speed UNIFORM is self defeating, unless you wish to increase the accident rate, for that is what interferes with flow. Of course, we could revert to a ridiculously low UNIFORM speed restriction under the absurd assumption that such a restriction would prevent injury in the event accidents occurred, and commerce would be arrested. Evolution and development would suffer. Individual (oops, sorry for using such a term when describing a UNIFORM world context) ability would atrophy, along with confidence and we would all become jellyfish floundering along praying that some unknown "they" have made correct planning decisions. Hey, isn't that just what is happening anyway in the US already? Yup, save the few who believe they can actually operate independently and take responsibility for such practices. Facts are facts. It is uncontrolled relative speed that is dangerous. But as has been stated, absent the desire to remain in our cribs, danger lurks in a bathtub with an inch of water in it, but it doesn't and shouldn't prevent those daring souls who wish to bathe from doing so. Don't you just hate such daredevils? Let's all stomp them out!! Just who do they think they are anyway??
I'll go back to sleep now. ZZZZ.....
Quick Reply: Are 928 Top End Speeds Getting Faster?
