info please - 85/86 32v injectors
I have never seen a US 85/86 32v car or its European equivalent, so I have a few questions....
1) I understand the fuel injectors (24#) are different physically to the ones fitted to the >87 cars - is this correct ?
2) How are the injectors retained at top and bottom ? What type of fittings ?
3) What alternative larger # injectors are available that will fit ?
Hi John,
I don't think there is a difference...I use the same 30# injectors on my 86.5 as Tony on his 87.
They are retained the same. The top is slides into the rail and secured by clips and the bottom stays put due to the down force of the rail mounted.
Bill (koenig928) installed 42# injectors with the help of your sharktuner
Someone please correct me if I'm missing something
Thanks Darien/Bill. That's just what I wanted to hear.
The reason for the questions is that we are working on the SharkTuner for 85/86 and we need to know what injector sizes are available.
Certainly the Euro 16v injectors are different, and I don't know what larger options there are for those ?
The Keonig is based on a >87 car, isn't it ?
"Certainly the Euro 16v injectors are different, and I don't know what larger options there are for those ?"
Yes, the 2v EFI injectors have inlet nipples: only an injector specialist could advise on other sizes.
The '85-86 are normal Bosch high-impedance injectors, @ 24lbs. The S4 injectors (also high-imp.)are identical in size, yet require a thicker o-ring at the nipple to seat in the S4 intake manifold: Ford motorsports injectors work in both 85-86 (no changes needed: direct drop-in for 24lb, 30lb, 42lb), and in the '87-95 as long as you source a new OEM nipple o-ring for those injectors for the S4 manifold.
Thanks Mark !
There was a thread recently of someone who sourced larger injectors fo s Euro (after one false start) - I must look that thread up....
Thanks Mark !
There was a thread recently of someone who sourced larger injectors fo s Euro (after one false start) - I must look that thread up.... found it !
https://rennlist.com/forums/showthre...tors+impedance
Originally Posted by John Speake
Thanks Mark !
I was just going to point you towards Kevin's thread, but you got there all on your own. Call Allen at Dr. Injector. He told us that he could source many different size injectors for all MYs. Tell him Leslie sent you!
Originally Posted by RngTrtl
I cant wait until the ST comes out, thanks for all the progressive work on the 928!
