Motor Mount and pan gasket party -Resolution
#61
Craic Head
Andrew,
Sorry, I just saw your other thread on the clutch. Didn't mean to bring up a sore subject. Glad you made it in time for the MI beer night.
I guess we can put this thread to bed, thanks for keeping it alive and for the advice as you went through some similar steps. I hope I don't need a clutch anytime soon, but if I do I'll look you up for advice.
#62
Andrew,
Do those bearings look as coppery in real life as they do on my monitor? If so, I think they all look well worn, or am I missing something.
Mike,
The clutch is a (relaively) easy job.
Mike,
#63
Andrew- I back-tracked through the thread but didn't see a reference-- did you go with the SPEC clutch? or 928MS? Impressions? More info needed!
#64
Supercharged
Andrew,
Thread 1 - Ahhh F! I think I f'd my clutch! Warning to 5-speed boostards
Thread 2 - Pics of a glazed Flywheel & leaky RMS
#65
Have you done a clutch yet? Getting everything out of the way takes most of the time. Of course I must admit, while my clutch is a dual disk, I have never dealt with an adjustment issue. It is also the same clutch that has been in the car since I got it in '89, including a dozen or so races and a few dozen track days.
#66
Craic Head
Stan,
Don't know who you addressed that question to. But since Andrew just finished one, I think it might be me?
I've done clutches before in several cars, but not a 928. I've always had to pull the engine to do it in the other cars, which I've read isn't required for this one, so I'm curious. Just not curious enough to try it until I need it.
#67
Hi Mike,
Actually my response was to our Cape Cod Euro S owner
The clutch in the 928 is surprisingly simply. The american muscle cars I worked on in the past required dropping the transmission. In the 928 there is a shaft that once uncoupled is slid backwards disengaging the shaft from the pilot bearing and it comes right out. Also makes reassembly easier as you simply have to align the shaft into the pilot bearing. With the american muscle cars the transmission had to be aligned, which made it a much more difficult 1 person job.
I haven't found a task on a 928 that requires two people yet....
#68
Craic Head
Hey Stan,
Didn't mean to interrupt your hijack of my thread . Just kidding. I really appreciate all your advice whether it's addressed to me or not.
I'm glad the clutch isn't THAT difficult, and from what little I've read about it the only thing you have to do is wear a helmet so it doesn't knock you out when it drops.
As far as no two man jobs, I guess that assumes you've got the right one there .
Thanks again.
Thanks again.
#70
Under the Lift
Originally Posted by Andrew Olson
RMS, sucks! Getting out wasn't too bad, but getting the new one in... I swore so much I ran out of explatives and had to invent new ones! Just when you think you've got it started, it pops out. PITA!
But it's done... finally.
#71
Supercharged
Originally Posted by Bill Ball
Fully agree. I pressed it in using two plates drilled with holes for two flywheel bolts to pass through. Snug the bolts and the plates push it in.
Originally Posted by Tom928
This maybe a stupid question; however, after you replace rod bearings is there a seating or break-in period?
#73
Anytime you've got exposed machined surfaces like crank or rod journals, it's ALWAYS good to do a thorough visual inspection as well as measurements to assure that all is within spec.
#74
I was wondering that same question too. I never got into block work, but everything above the block (cylinder heads, etc.). I remember when I was a kid and my dad replaced Crank or Rod bearings, he used some type of gauge or putty. I was too young to understand nor had any interest at the time, so I didn't catch that lesson. Do you just buy the bearings and install, or are there choices in sizes? Also, kinda OT, but can you pull a piston and change rings through the bottom?
#75
The stuff your dad used is Plastigage, it measures the clearance from the crank to the bearings.
I don't think you can pull the piston from the bottom with the crank in place. You'd do more harm than good, even if you could. Bearings are made in different sizes to account for machining that may be needed on a crank. If the crank has been machined, you'd have to go with the appropriate bearings. If it is stock, and you're using standard bearings, the Plastigage will confirm that the clearance is proper.
