'85 "Horseshoe" Gas Hose...How to fix?
This used '85 32V "Horseshoe shaped" gas hose from the backside of the engine is a bit stiffer than I'd like to put on my car. Is it possible to have a hydraulic hose company refit these ends with a new hose? Or does someone have a new hose for sale? Part number 928 110 271 00
Harvey
Harvey
Harvey
928 int'l or specialist should both have it. I wouldn't bother to try to have it rebuilt. The hose was ~ $30 (?). I would also replace the other fuel hoses which are 20+ years old. After I replaced my U I bent the old one and it snapped in two.
Originally Posted by Greggles
Harvey
Glenn
Any good hose shop should be able to build that for less than $40. Look in the phone book for "hydraulic hoses". I recently had a line built that allows me to install a fuel pressure sender between the passenger side fuel rail and the pressure damper just in front of the water bridge.
N!
N!
Originally Posted by sharkmeister85
Isn't that one of those parts that was on the NLA list posted by Mark Anderson in a thread recently?
Glenn
Glenn
Harvey
Harvey
Harvey
A while back there was a post that indicated that the newer design from the later models "might" work. Has anyone confirmed if that is the case. I just reaplced all my lines, except this one and while the hose seems OK I really hate trusting a 20 year old fuel line.
Under the Lift
Glenn
Glenn
I went out and had one built for $20.00.
