Car is 'unalignable'.....
#46
Originally Posted by BrendanC
An aligned 928 with new suspension and steering bits drives 1000% different then an unaligned 928 with 50-200k miles bits and pieces.
#47
The racks still move too much under nominal pressures applied for my perception.
The 911,912, 914,930's all had hard mounted racks. As they say "sometimes you can tell if a dime is heads or tails when you run over it".
On the 928,924s,944,951,964,968 and 993 the racks all have vibration mounts between the rack and cross member; whether the design is the 4 point press and swaged vulcanized 928 bushings, or the simple wrap around sleeves or cuffs with the others. I drove a 964 a few weeks ago, comparing it to my (911), besides the more forgiving cushion springs in the rear, the power assist in the 964 as compared to the manual 911 felt strange, responsive but strange.
You could go the route of solid mounts however the vibrations have to be absorbed somewhere other than into the joints, the wheel and your fingers.
So somewhere in the design stages back in the mid to late 70's I guess the powers that be found a reason for "da floating" mount.
The ends, (as mentioned) when moved out to a high degree (a moderate speed corner, with opposite corrections, say, the bowl at SOW), move back and forth, thereby creating unknowns in the steering geometry. With this movement comes movement of the seals keeping things dry. A stiffer rack will be a longer lasting one it seems.
As far as movement in the rack shaft between the shaft and the seal, you need a minimum clearance and a particular micro finish (a min and max) on the shaft to insure there is a minimum amount of oil left to provide a lubricant for the lip of the seal otherwise they'll rip or burn.
The rack on my Honda is Electric, somehow (I signed a contract with my wife to not take it apart), yet it is HUGE in diameter, as are the rack ends. It is bolted more solidly, and seems to be much stiffer by cursory glance then the ZF racks we have controlling a car nearly 1000 pounds heavier.
Thsi is OT now, but anything we can do to make these things BETTER then new will help us catch up the 25 years that have passed since they may have been "good" technology.
Well maybe. Its all a matter of dollars/units. If you can increase the one of the right the one on the left starts looking better.
Just blowin off the day here Brendan. Now. Where did that Windex bottle go?
#48
Originally Posted by griffiths
Hey. Isn't the unexpected the thrill of it all. Heck, lets just drop the tires and run on the rims. Without kidding here I enjoy the feel of the 928 as it is.
Does the spool valve main shaft need to be surfaced?
Does the seal go lip out or in? As in down or up?
Do the 91+ racks actually have different seals then what is Supplied by Corteco/Fruedenburg NOK for all earlier racks?
Are there rebuilt pieces available for the later steering pumps?
They come apart - I know that. The early pumps were rebuildable, with pieces readily available. The WSMs even had the procedure. Not so with the later pumps.
#49
How do I lessen the spring tension in the spool valve to lighten up the steering?
Long Answer
Well lets see what they tried to do before 91 or so.
I guess between 78 and pre 85 they had a steering system designed with a rack and a pump that had a threshold cut out of 75 bars.
The rack went through 3 design changes then. The first changed the path for air displacement between the boots or bellows from the exterior via the black plastic tube to the interior, through a partially hollow shaft (you need the “displacement” we’ll call it, for the term of the moment, or was it Luftversetzung Weg? or else the boot will pop off the rack end). That cut the weight down of the rack assembly a pound or two. Planned for? Who knows.
Then they lengthened the rack shaft a few cm’s. Why? I don’t know. Maybe someone said something about “stay away from the tie rods Henrich, if Otto finds out your goose is cooked”, or maybe the parent company's sister company was on one of those 3 month Euro vacations. Anyway the rack shaft got longer. A few internal parts changed, such as from a bronze bushing/back-up washer to a (cough) plastic bushing. A steel back up washer (cough) became plastic. Somebody said the cost for the cushiony steering stops were overinflated and someones’s cousin had a screw machine shop that was slow, so they changed the steering stops to a one piece aluminum donut with a liquorice flavored o-ring inside. Otherwise the rack remained the same in terms of fit, form and function. Then around 1985 or so Klaus said “Hey Hans!. Dis fella called ya and he vandid you to make his steeering ezer”. So Hans thought about the torque bar, connected inside the input shaft/pinion’s spline, connected to the spool valve, connected to the pinion gear and Hans said “Ey, vata aya Nutz!. Just tell the fella to Pump Ur Up. Idz da same ding. Or geta bigga veel”. Now Klaus was a smart guy when it came to people skills.
And he knew if he if told this fella to simply pump up the pump pressure or to find a bigger steerng wheel the guy would either laugh at him or throw sausage at his car. So Klaus simply said "Sorry sir. That is not the way this car was designed to perform".
Well sometime around 1985 Fredrick, one of the second cousins who ran the rack plant, anyway Fred was making all the power steering pumps, and he was making a ton of money because he was using the same casting tools for this pump that he used for the bimmer pumps and he had charged both customers for the same set of tools (some business people are smart). So one day these fat cats are strollin through his plant getting the nickel tour (do they have nickels in Europe?) and they see whats going on. They took poor Fred outside, handcuffed him to an old VW and made him were a sign that said "I'm not a VW I'm a Porsche". I'm getting carried away here aren't I. Bottom line they decided to make a design "improvement" (cutting down on raw materials and the weight, I think it was the weight that was the selling point) and they basically took the same internal parts in form and function and dropped them into a different housing. By the way the bimmer company and the P company both ate the tooling.... again.
Then around 1991 or so someone found this poor old fella sitting on the front steps of the P facilities corporate office, well no, actually he was leaning against the building trying to hold it up. When they approached him he whispered somethng that sounded like "E. Z. Steering". So they carefully pried him off the stainless steel column, amazing how the skins sticks to metal when it gets cold outside, and huddled him into the Vorsitzender's Office (thats the guy who watches chairs) and sat him down. The Chairman asked who this old ratty looking fella was and they said "Why Sir. This is Mr. E. Z. Steering".
So things kinda grind to a halt here,,,, and that is exactly what they did.
They ground down the diameter of the torque bar to make things more flexible.
No. Maybe I'm wrong. They enlarge the diameter the torque bar to make things more stiffer. Anyway they did that. And its suppose to work.
And of course a competitor in on the seal end of things, who wanted the seal busines for years, showed up the next day. The other fella, what's his initials....CfW? Heck, we'll just call him Charlie F W. So Charlie made his seals using black stuff and these new guys, let me think KOCA or COkA or is it KACO, anyway they were really sharp. They presented a set of seals that were not black but green/blue, no maybe closer to a Bermuda green. Lovely things. And they added a few extra ridges on the contact lip, kinda a mix between a design patent and a utility patent, and called the stuff it was made out of something like SoyGum. Anyhoot, these new seals were presented because they had special properties, such as high heat resitance and wear resistance. The size is the same but they are special stuff. And someone else came along, maybe related, ya never know, and they said "Hey, ya know that problem you got with rings grooves forming in those castings that pinion valve thing goes into. We'll mine are Bermuda green too! Well the OEM vehicle guys new a good opportunity when they saw it so it was time for a SUPERSESSION ! That's right! Change the bill of materials. Time for drawing revisions !
As you recall Fred was handcuffed to a 914, or was it a VW. Anyway Fred's wife finds him out there one day, sooner or later I don't know, and she takes out an old hack saw blade, I think it was P tool P1427, and she cuts of the cuffs and drags Fred home. She says to Fred "Tsk Tsk. Uze supose da me my huzband. Wer da heck have you bin?. I'll tell ya wear ya bin, you hav bin hanging around doze lousy VW's too long! In the mean time ur couzin haz bin changin al kindza things. Itz tyme you made sumthin of ur zelf". And she throws poor Fred back onto the street and tells him never to come back until he's done something useful.
So Fred is walking down the street and he runs into poor Charlie F. The guy who made really good seals for along time but he lost the account with P or was it the Z guys. Charlie tells him that his competitor came in one day and sold P on a snow job about seals they needed which withstand higher pressures and so forth. Fred thinks about this and suddenly a light buld goes off and he runs back to his shop and proceeds to build the HP Super Pumper! A few weeks down the road Fred sold the new design to P, kicken up the pressure from 75 bar to 100+. Plus he go he got a bonus for.... that's right,
another SUPERCESSION! End of story.
Short Answer:
You don’t. You either increase the pressure or increase the diameter of the steering wheel. Again a matter of dollars divided by units. And as a side note the Boxster/996 may have gone the same route, with respect to the "stiffness" of the torque bar.
Long Answer
Short Answer:
#50
[I]I have a hard chromer here in San Diego. Last one standing. Should he chrome the whole shaft? How much can be added, or rather, should any be removed before Chroming?
Count his blessings that he is still "standing". You would only hard chrome if the shaft diameter was not within tolerance or became so after removal of imperfections. You would not know if it was or not (out of spec) unless you mic'd it. You would also have to determine how much the shaft is out round. Then resurface the shaft, or if severe grind back, hard chrome, bake out for hydrogen embrittlement, grind to spec. You would "mask" the gear side, the inner threads for the tie rod ends, and the piston's snap ring grooves.
How much hard chrome... .well how much do you need to "finish it up"?
The spool valve is an assembly with the pinion gear and input shaft. There is a low pressure seal on the top and one of the bottom. There are four high pressure sealing rings, "skeeved" (****) as they say along with back up orings.
Geez! some guys just want egg in their beer! The lip contacts the shaft.
Which side (cup) faces the what is determined by examing the function.
That is a difficult question to answer because, isn't Corteco a div of /Fred; providing distribution and NOK a mfg?
What kinda of rebuilt pcs?
They come apart - I know that. The early pumps were rebuildable, with pieces readily available. The WSMs even had the procedure. Not so with the later pumps. OK ?
#51
What is the minimum diameter of the shafts on early (really early) and 85+ racks?
#53
Charles: How do I lessen the spring tension in the spool valve to lighten up the steering?
#54
Which side of the shaft?
The early is the same as the late.
The "Smooth Side" as you have described.
#55
#56
So Brendan, I think we have strayed enough from 959's original topic, alignment, we gone past the suspension issues and now we are down to subcomponents.
Before we go, tell me, when are you going to the put the Avatar back in the beast it came from?
#57
http://cgi.ebay.com/ebaymotors/Porsc...60558980QQrdZ1
#59
[QUOTE=griffiths]
Did you watch the video? Where would I increase the pressure from the pump? On that valve on the side?
later pump kit from rennbay:
And I thought I was looking at the makings of a high spun ice cream maker.
.... ah darn.
.... ah darn.
#60
[QUOTE=BrendanC]
Watched Video: Yes
Critique: well lets see if we can set a better example this time, lot's of tomatoes still on the screen
Positive suggestions
A) It would be easier if you use a 13 mm wrench
B) You NEVER
hammer seals, you press them:
C) If the pump has internal leakage or noise because the vane guides
are shot, or the cam is shot, new seals won't help you
Why don't you buy a remanufactured pump or a "new" pump already with a higher pressure? You could call Jeannie or David at 928 Spec.
http://www.928gt.com/
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
B) You NEVER
![order](https://rennlist.com/forums/graemlins/order.gif)
