A/T Hard Shift - found the culprit
After replacing my Idle Stablizer Valve in my 87 S4, i found myself with a high, but stable idle (around 1500 RPM), and a hard-shifting transmission. I dug around the vacuum connections, and found that the vaccuum tube connected from under the intake to the 5 way splitter was disconnected (of course, it was disconnected under the intake
). So, back off came the intake and i connected it back up. Buttoned everything back up, took her for a test run, and the idle was better, but the shifting was as hard as ever.So, back to the detective work. Tested the vacuum for the line from the 5 way splitter back to the transmission - no vacuum. Took the vaccuum connection off the transmission - was a bit chewed up, but looked ok. Plugged that connection and tested again - still no vaccuum. The vaccuum line runs along the top of the torque tube, and is a combination of plastic vacuum line, flexible rubber vaccuum line, and metal vaccum line, but I could not get my hands up to the top of the torque tube to check for problems.
Well, i resigned myself to pulling off of the exhaust, and the heatshields to get to the top of the torque tube, and lo and behold, the connection from the plastic vacuum line to the metal vaccuum line was completely disconnected! There is no way i could have checked this without a full exhaust removal - crazy in my opinion. Hooked this up, tested vaccuum, and finally had it (except it wouldn't hold vaccuum). So I clipped about 1 CM of the chewed up rubber line into the transmission, reconnected, and had full vaccuum that held for 20 minutes.
Reinstalled the heat shields and the exhaust, took her for a spin this morning, and all was well - nice and smooth shifts - amazing!
Hope this helps someone in the future - if you don't have vacuum from the 5 way splitter all the way to the transmission, you have 3 connection points to test, plus the vaccuum lines themselves - anyone of these could be the culprit
Good luck!Here is a picture of the nasty bugger that was so hard to get to...
By the way.... what is that open piece of pipe poking through the grommet behind the torque tube?
Brian - i have no idea what that that leadss to - i imagine it contributes to my heat issue in the cabin - which is why i stuffed a bunch of insulation up there. Maybe something to do with a 5sp tranny?
