928 Forum 1978-1995
Sponsored by: 928 Specialists
How to convert to LSD?
Old Sep 20, 2006 | 01:32 AM
mark kibort's Avatar
mark kibort
Tranmission doesnt have to come down. just open the rear up, remove the cv joints and start pulling things apart! the LSD does need some finessing to get it in and shimmed properly, but its a pretty easy job. I think its a 4-6 hour shop job.
ive had it done several times. '84, scots 82 and the holbert machine.
mk
Old Sep 20, 2006 | 03:39 AM
Bill Ball's Avatar
Bill Ball
Under the Lift
If Mark did a diff swap on his 87, then my casual eyeball measurments are wrong. On my 89 it sure looks like the gas tank and battery box are too close to maneuver the LSD into the carrier.
Old Sep 20, 2006 | 09:10 PM
FlyingDog's Avatar
FlyingDog
Most of the LSDs I've seen for sale are $650+/- $200.
Originally Posted by Andre Hedrick
Which gearbox do you have G28/?? I have an LSD w/ 2.75 in a complete gearbox, which I would consider parting with the rear-end section. The LSD is really tight, and feels more than 40% but who knows. Also I have new dual cap distributor for the 84/85 euro's that needs a new home (box is collecting dust).
A 2.75 gearbox (G28.03) would be pre-83 so fitting it to her 85 (G28.10) would be more work. G28.05 is also pre-83. G28.07/08 and up are 83+. The distributor caps and rotors are new? If so, I'm interested.
Gio, 89 S4 5-speed is 2.64. Probably the only more desireable gearboxes are 89GT and 85-86 Euro.
Bill, I think you're right. Even if the open diff could come out, I don't see an LSD going in between the battery box and diff case. Samantha's 85 would be before the extra room for split exhaust.
Old Sep 20, 2006 | 10:20 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
These must be eBay specials. A decent used one from one of our better known vendors has been on the plus side of that since I can remember.
Old Sep 20, 2006 | 10:23 PM
FlyingDog's Avatar
FlyingDog
Most were people selling on Rennlist and a few on ebay. I don't think I've seen more than 15 for sale. Porken was selling 2 a year or so ago for I think $350 and $450.
Old Sep 21, 2006 | 01:03 AM
Andre Hedrick's Avatar
Andre Hedrick
Rest in Peace
Default EBAY QUICK!
NEW LSD ON EBAY
Old Sep 21, 2006 | 01:12 AM
Bill Ball's Avatar
Bill Ball
Under the Lift
That one was for sale about 8 months ago from the same place, but he said at that time that it was "probably" from a 928. It didn't get any bids. It looks right.
Porken was givng them away unless they needed rebuilding. The ones I got from 928 Intl have been real nice.
Old Sep 21, 2006 | 01:18 AM
bigs's Avatar
bigs
Dean of Rennlist, "I'm Listening"
Well, first there are the missionary visits.
Then there's baptism.
Then there's this 10% tithing thing...
Then... Oh, wait! I thought you wanted to know how to convert to LDS!
Old Sep 21, 2006 | 04:07 AM
mark kibort
I forgot, my S4 is really an 86 chassis, does the batterybox change ?
mk
Old Sep 21, 2006 | 04:10 AM
Vilhuer's Avatar
Vilhuer
Mark, in your case its most likely same as S4. Earlier cars had longer box. It was shortened in '86 MY to make room for double exhaust.
Old Sep 21, 2006 | 10:09 AM
samantha's Avatar
samantha
Thanks for the heads up... but how do I know for sure this will work on my car?
Old Sep 22, 2006 | 12:33 AM
Andre Hedrick
Rest in Peace
Default Re: Question for item #260033029572 - Porsche 928 limited slip differential
Samantha,
"Numbers stamped on housing are:
4061006205 550780 S40
Number on CV flange: 928 332 206 00.
I think will fit cars up to 1985."
This is the answer I got from the seller.
After looking up the part number in PET5, my best guess is I am clueless cause I can not find the partnumber at all. I get error 2 in PET5
Anyone else who can help?
Old Sep 22, 2006 | 04:22 AM
Bill Ball's Avatar
Bill Ball
Under the Lift
Well, he's right about the joint flange 928 332 206 00.
Old Oct 9, 2006 | 12:14 AM
Andre Hedrick
Rest in Peace
ebay lsd again
Old Oct 9, 2006 | 12:36 AM
RyanPerrella's Avatar
RyanPerrella
There is an LSD unit that the seller claims to be brand new on Ebay, do a search, I think it was $800 or so
